Transmission question non fbody.
If that is the situation at hand, then purchase a re-manufactured unit, or have the unit rebuilt.
Most of the Auto. Trans. Flush-Systems will move the ATF backwards through the system... Avoid these.
For the future; maintaining a new/ healthy unit with a flush in the normal flow direction is fine with a filter change.
Or just drain and fill with a filter change more regularly.
At 161,000 miles; the ATF and filter should have been changed a minimum of 3 times.
Not doing so... will often condemn the transmission to being damaged at this point.
Like I said... install a reman.unit, or rebuild your unit.
There is no point to doing a repair at this mileage (with no service ever done)... something else will fail soon, if so.
I was a Corporate Engineer for GM... I have copies of owners manuals and service intervals for all GM vehicles sold in North America from 1980 to current.
Your manual prescribes an ATF (or ATF and Filter) change:
-every 100,000 miles (if reached in 5 years, usually expressway driven mostly).
__________OR__________
-every 50,000 miles for vehicles that make more short trips more often. including states with heavy snow, long winter temps, or long high heat summers.
For any of you that purchase a New GM vehicle (or any vehicle with life time fluids)... do NOT follow the owner's manual service intervals.
They have been written so that your new vehicle should intentionally start experiencing multiple system failures (one after another)...
shortly after the 100,000 to 120,000 mile mark.
If you plan to try and keep a vehicle past this mileage...
Then you MUST CHANGE THE FLUIDS!!!
This reflects the average driver.
Should you drive like the stereotypical "Old Lady/ Grandma" then reaching a higher mileage is likely.
However...
Should you drive like you think your driver's license is a "NHRA Competition License" then reaching an even lower mileage is likely.
