2005 corvette auto transmission 4l60e?
Old Apr 22, 2021 | 03:22 PM
95maroz28's Avatar
Default 2005 corvette auto transmission 4l60e?
what kind of transmission does the 2005 auto 4 speed corvette have? same 4l60e as 2000 camaro z28 and 2004 gto ls1? are tailshafts different. What would you need to fit a 04 gto 4l60e or 2000 ss ls1 transmission in the 2005 corvette that has a broken transmission?
Old Apr 22, 2021 | 03:27 PM
Edward Stark's Avatar
Your 05 Vette C6 has the 4l65e. RPO "M32".
DONT buy a used tranny. Repair your's.
Contact Ryan from Performabuilt for that. These guys create some killer 4l's.
Your tranny is gold. It holds (520 N⋅m) of torque STOCK. It has 7 frictions and 5 pinion planets.
Switching a Vette 4l65e to a 4l60 would be a huge downgrade.
Or contact Chevrolet and ask how much the Supermatic
4L75-E costs. It's an OEM beast and a direct replacement to the 4l65e
The camaro never had your tranny, the Pontiac GTO only had it years 2005–2006 [M32, 3.46:1 final drive)]
Old Apr 22, 2021 | 03:53 PM
vorteciroc's Avatar
Corvette 4L60E family transmissions are not interchangeable with non-Corvette transmissions.
To swap one transmission from one to another...
The entire transmission needs to be disassembled to change the output-shaft.
The bell-housing and other parts also need to be changed as the Corvette transmission does not attach to the engine.
The corvette transmission is attached to the rear differential (in the back of the car obviously).
A "Torque-Tube" attaches to the back of the engine, and goes all the way to the back of the car where the transmission is (no drive-shaft is used).
Old Apr 22, 2021 | 03:55 PM
bbond105's Avatar
The 5 pinion planets are weaker than 4 pinion planets.
Old Apr 22, 2021 | 04:25 PM
You have to avoid the 5 pinions from a Monster transmission and other aftermarket cheapys. use OEM only.
The 4 pinion planetaries aren't the weak link in a 4L60E anyway. As i've seen online, the 5 pinion used for high torque applications.
Old Apr 22, 2021 | 04:53 PM
vorteciroc's Avatar
No 5-Pinion planets period.
I have posted a few times about the differences between them...
anyone remember where I posted photos?
Old Apr 22, 2021 | 05:07 PM
Did you use the GM Ones?
Alright, No 5 planets and no sonnax checkvalve. I'll tattoo that to my GF's forehead and show it to people xD.
Old Apr 22, 2021 | 06:16 PM
vorteciroc's Avatar
Have I used GM 5-Pinion Planets?
Yes, but only for testing... I need to find an old post of mine for you.
I was also an Engineer for GM at the time these 5-pinion planets were conceived...
They are junk... and yes the aftermarket versions are even worse.
Use this hyperlink to another Thread and read my Post #8:
Hyperlink
Old Apr 22, 2021 | 06:20 PM
98CayenneT/A's Avatar
Is post #8 here what you're looking for....
https://ls1tech.com/forums/automatic...n-planets.html
Old Apr 22, 2021 | 10:09 PM
vorteciroc's Avatar
Thank you 98Cayenne!
Old Apr 23, 2021 | 08:18 AM
MaroonMonsterLS1's Avatar
"DO NOT replace 4 pinions with 5 pinions. I've never ever (even in 1000 hp 4000 lb cars) seen a 4 pinion blow up. Ever. I've seen them get ruined from lack of lube...but a 5pinion will suffer the same fate. The 5pinion is actually different in construction than the 4 pinions and really no stronger."
-Me, circa March 2018
Just when I think the "5 pinions are junk" horse has been beaten dead....it decides to come up again haha
For anyone reading, Myself, Vortec, and multiple others have shared multiple times that EVEN OEM 5 pinions offer no benefit and are likely a detriment compared to a good condition 4 pinion
Old Apr 26, 2021 | 11:28 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
If you decide to replace the torque converter at all make sure you get a 2005 specific converter. 2005 and 2014 Corvettes are both odd years where the converter ONLY fits those years.
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
