4L60E No 2nd and 4th
Now, upon the test driving, it appears I have no second gear (and possibly 4th - will get to that in a sec). It will run to 2500-3500rpm in first then shifts to 3rd (shifts easier if I let up on the gas). Also, when it shifts it somewhat feels like it going into 2nd for a split second.
Manually shifting does not help. External wiring seems fine. I tested the servo end play to be about an 1/8”. Of course I changed the band, the reverse input drum was not visibly worn, both solenoids replaced (including the pwm and tcc) also installed a remanufactured torque converter.
Here is why I am not sure if I have overdrive: I am pretty sure the vehicle went into “limp mode” due to a rare and sporadic/reoccurring knock sensor code that I will address later. This made it run like @$$ from stop to go (of course this happened on my very short 4th gear testing). Anyways, given my meager understanding of transmissions I am afraid to drive it at all to retest in fear I might damage something.
I was about to take the pan back off and test the solenoid and wiring as well as to verify the valves behind the solenoids are not stuck or installed backwards somehow (which I checked twice on rebuild), but I am beyond annoyed with this project and likely will break something or hurt myself. And I don't think that would explain 4th. So here I am
Can anything there anything else do this?
The rebuild was done due to loss of 4th and reverse. The only “hard part” I found damaged/worn/broken was the drive shell.
Is this a 4L60E Transmission, or a 4L70E Transmission with an Input Speed Sensor?
The Sun-Shell/ Reaction-Shell was damaged, resulting in NO Reverse, 2nd, and 4th Gear-Ranges... Correct?
What is the Year, Make, and Model of the Vehicle?
Is the Vehicle Stock or Modified?
If Modified; what was changed (Engine, Differential, Etc...)
Did the Final Drive Ratio or the Tire Height significantly change?
Did this Vehicle originally come with a 4L60E Transmission?
Was the Transmission just overhauled back to Stock... or modified/ upgraded in any way?
What are all the Power-Train DTCs/ Codes (Engine Codes for example, can affect the Transmission)?
Limp-Mode will generally have the Transmission operate in whichever Gear-Range that does not use any of the Shift Solenoids.
In this situation, that would be 3rd-Gear... as Both of the Shift Solenoids are OFF for 3rd-Gear.
Power-Train Control Module Diagnostic Trouble Code P0756 pertains to 2-3 Shift Solenoid Behavior/ Performance/ Malfunction Detected.
This is NOT an Electrically related condition for the 2-3 Shift Solenoid... Normally a physical/ mechanical issue is at hand for this DTC (unless additional DTC are set for the Shift Solenoids electrical circuits).
P0756 will NORMALLY set when the PCM is commanding 1st-Gear or 2nd-Gear (depending on vehicle speed and throttle input), but instead the Transmission goes through a 4th-3rd-3rd-4th Shift Pattern.
Depending on your answers to my questions... This issue may be a circuit leak, Valve-Body issue, or an incorrect component used...
There are many other possibilities depending on the answers you provide...
So answer them, and we will continue.
No.
Do not know how to check this without some sort of VIN lookup, but yes?
P0332: Knock Sensor 2 Circuit Low--cleared and has not come back (this is a rare and seemingly random issue with this vehicle)
And I don't understand what you mean by 4th-3rd-3rd-4th Shift Pattern. (Apologies if I am being dense.)
Should I try to test for 4th again? Or is that too risky? I know I put this thing together, but I have yet to wrap my mind around how it all works in practice.
Thanks for your thoughtful response! And I hope I answered everything adequately.
I don't just type all this stuff at 3 AM for my health.
If I put in the time to try and help you...
you could at least try and answer the questions.
I was exhausted when I responded.
Thankfully, I kept a document at work with my I original response (with a few updates):
No.
Do not know how to check this without some sort of VIN lookup, but I pretty sure is came with the 4L60E stock.
UPDATE: after about 100 miles (nearly all highway) the check engine light is back on will update once I am able to scan it.
Not sure what you mean by "4th-3rd-3rd-4th Shift Pattern" because I am almost sure there is no 4th at all. However, the highway cruising RPM is seems identical compared to before the rebuild.
I will try to PM you if that is ok?
I even posted a few more times and the forum still shows I only have 4 posts.
And because I am not a big boy on the forum, I cannot even send PMs it seems. Send me a pm so i can respond or email me at synauxcc@gmail.com....
I swear I am not trying to be difficult
Regardless, I will attempt taking the original post and split it up is sections:
Fairly stock, I am not the original owner and I sometimes wonder if the ECM was tweaked, but other than that, stock to my knowledge.
I am almost sure there is not 4th at all, but the highways cruising RPM is seems identical compared to prior rebuild.
Well, I don't know why all this wouldn't post as one long message but it is on here now!
Hydraulic fluid moves the arm of the Floor-Jack, when the lever is pumped.
However, the Floor-Jack has two sensors and a computer that monitors the position of the Floor-Jack Arm.
One sensor at the very bottom of the Jack Arm travel, and one sensor at the very top.
This way the computer can process data of the Jack Arm being all the way up, or all the way down.
Lets say that you are pumping the Jack Arm up as far as you can get it...
But the Jack Arm does not make it all the way to the top of its travel.
You look for computer codes and find one saying that the top sensor does not read the Jack Arm as at the very top position.
There is nothing wrong with the sensor, even though there is a code related to the top sensor.
The problem is hydraulic, preventing the Jack-Arm from going all the way up.
This same theory applies to how Automatic Transmission monitoring occurs.
So is it possible I installed the valve backwards or something for solenoid B?
But even if I did, I imagine the code would come back (which it hasn't).
Any idea what might be the root issue?
Another thing I noticed is if you punch it on the highway it shifts to first. And when it does this (not always and I might be delusional) it feels like it slides into 2nd first for a split second same for 1st to 3rd, but it is very subtle and very quick.
Are these things worth considering: Wiring harness, ecu, speed sensors, perhaps one of the three sensors swapped on the diff (all have the same connector, I believe)?
Thanks
It had some odd crimp connectors. If my research is correct, if those connections weren't crimped correctly that could explain no 4th (but doesn't explain no 2nd), correct?
Depending on the conditions in which the vehicle was operated (driven), the period of time required for the Diagnostic Trouble Codes to return may take a long time.
Has the vehicle been driven on the expressway or regular roads? Both the expressway and regular roads?
The DTCs can take hundreds of miles to return depending on the driving conditions.
The PCM is constantly monitoring data from all of the Power-Train sensors.
However the DTCs are not set from the PCM processing all of the sensor data...
This is because originally the CPU and RAM of the PCM were too slow to process all of the sensor data simultaneously.
Today the PCM could actually do this, however the PCM does not.
So, going back to the start of OBDII in 1996... these slow operating PCMs had to have another way to take processed data for an individual sensor, or sometimes a group of related sensors... and determine if any DTC needs to be set.
The way that this was achieved was for the PCM to complete a series of self-tests on the sensors, or sensor groups one at a time.
The number of self-tests varies from vehicle to vehicle... but there are usually 4 to 12 tests to be completed.
The different tests are completed under different driving conditions... and done one at a time.
So unless you have access to a DTC scan-tool or computer program to look at the PCM data and test information...
to be patient in waiting to see of the DTCs return.
Generally if the vehicle is not operating normally... then there is a very good chance that the DTCs will return.
In regard to what the issue actually is... I am going to reference my prior statement:
"DTC: P0756 pertains to 2-3 Shift Solenoid Behavior/ Performance/ Malfunction Detected.
This is NOT an Electrically related condition for the 2-3 Shift Solenoid... Normally a physical/ mechanical issue is at hand for this DTC (unless additional DTC are set for the Shift Solenoids electrical circuits)".
Most likely there is a hydraulic or mechanical issue.
Unless you feel that you are capable of disassembling and diagnosing the Transmission on your own...
I would bring the vehicle back to the Business/ Shop that rebuilt and installed the Transmission for you.
Good luck.
