4l60e rebuild?
Old Jun 5, 2021 | 11:00 AM
Eric23_Z28's Avatar
Default 4l60e rebuild?
So I want to rebuild my 4l60e trans from my 02 camaro z28 with a 5.3 lm7 (ls1 blew) I do want to lsa supercharge it later so what do you guys think is it worth it or just buy a 4l60e that’s been rebuilt already?
Old Jun 5, 2021 | 12:49 PM
vorteciroc's Avatar
The Stock LSA Supercharger has "Rectangular" Ports that match with "Rectangular" design Cylinder-Heads...
such as the LSA or LS3 Cylinder-Heads.
These "Rectangular" design Cylinder-Heads, require a Cylinder-Block with a minimum of a 4.000" Bore.
The 5.3L Cylinder-Blocks so not have a large enough Bore to accommodate the "Rectangular" design Cylinder-Heads...
A 6.0L or 6.2L Cylinder-Block would be required to use the "Rectangular" design Cylinder-Heads.
The Aftermarket produces different Intake-Port Adapters that allow "Rectangular" design Intake-Manifolds or "Rectangular" design Superchargers to be used with "Cathedral" design Cylinder-Heads.
Using these Adapters would be far from ideal...
However the 5.3L Engines with "Cathedral" design Cylinder-Heads would now allow for the LSA Supercharger (with "Rectangular" design Ports) to fit/ work together.
Old Jun 5, 2021 | 03:03 PM
Eric23_Z28's Avatar
Thanks for letting me know but before I supercharge it I want to rebuild or get a already rebuilt 4l60e trans cause my 4l60e I got now is not the best (slips/changes gears late).
Old Jun 5, 2021 | 03:57 PM
Bspeck82's Avatar
I have an extreme automatics trans. Works great and customer service was amazing.
Old Jun 5, 2021 | 06:28 PM
vorteciroc's Avatar
What area of the Country do you live in?
Old Jun 5, 2021 | 08:16 PM
Eric23_Z28's Avatar
@Bspeck82 what stage trans did you get and @vorteciroc I’m in the Michigan area.
Old Jun 5, 2021 | 09:34 PM
vorteciroc's Avatar
@MaroonMonsterLS1 has a high-performance Transmission Business in Iowa.
I strongly recommend that you contact him for your Transmission needs.
Old Jun 5, 2021 | 10:30 PM
Eric23_Z28's Avatar
@vorteciroc thanks I will check him out.
Old Jun 6, 2021 | 09:35 AM
Bspeck82's Avatar
Whatever the 700hp was at the time. I think he revamped his program now.
