tci converter?
The converters SOLE purpose is to take whatever output your motor is making and transfer it to the transmission. Because of that it can make a world of difference between the car feeling great to drive/race or leaving you wanting more, so choose wisely.
-Dalton
Our SB Series of converters are an upgraded version a factory converter. We furnace braze and tig weld fins, install a better lockup clutch, add bearings in place of washers, and raise the stall. We still only rate those converters 450HP.
I'm not going comment on TCI's product since we do not manufacture them. I will say like most other converter brands we can service them.
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
FTI Performance ESRL3380
1-866-726-8358
FTIPerformance.com
ESRL is a 9.5" converter
SB2400LT30 is a 12" converter
2004 and older Corvettes take a normal 700R4 converter, 2005 takes a special design only for that year, 06-13 have there own design as well, 2014 is by itself with a standalone design, and then the 2015 and up 8 speed vettes have their own design.
The 2 converters mentioned above will fit.
1-866-726-8358
FTIPerformance.com
I can't speak for the parts or quality of the other brands but our ESRL series uses the factory 245mm stamped steel cover and piston for lockup.
1-866-726-8358
FTIPerformance.com
