4l80e dipstick issue
I also noted that despite there being two O-rings, it's really loose where the dipstick goes into the transmission. Is there supposed to be a hold down or anything like that? Should I just put some beefier O-rings on there or just suck it up and spring for the lokar piece? Any help or advice would be greatly appreciated.
Here's a picture of the dipstick where I marked it to the correct level, and where it goes into the transmission.
https://imgur.com/a/giJqsrK
On mine I had to see where the full mark was related to the transmission and loosen the two screws to allow the blade to slide up into the handle till the engraved mark on the dipstick was at the right spot. had my dad hold the handle seated while I tapped on it from the bottom. I used a good punch to put a mark on the blade against the handle so I could make sure it doesn't move Once I'm happy the blade is getting sleeve lock locktight on it...
