4L60E Problems (slipping/not shifting)
On first test drive it wouldn't back out of the garage which I determined was due to low trans fluid level. I had replaced the trans filter and added fluid but not enough. Added fluid and drove it and it seemed ok. I then had it tuned with a cable loaner where I uploaded the tune based on the file he emailed me. We did a couple rounds back and forth as I logged data and sent it in. During this time (the first time I went wide open throttle for logging) I noticed it would bounce off the rev limiter a couple times before shifting into 2nd. I'm talking a couple quick bounces up there at 6000 before shifting. Normal driving shifts in general seemed slow too. A day or two later I'm logging some more and its worse. Now it's bouncing several times off the limiter before shifting and seems to be slipping while driving in 2nd or 3rd. I get home and the fluid level is too low as in dipstick dry. I added a quart and level is good now but its slipping and wont even shift out of 1st unless I let off the gas completely. I can drive part throttle up to 3000 rpm which is 25 mph and even hold my speed but it won't shift unless I'm completely off the gas. Once in 2nd or 3rd its ok but will slip if I give it moderate gas. Did I destroy this trans by beating on it with low fluid level? I would guess I did maybe 4 of 5 wide open throttle runs up to the 1-2 shift and only 1 or 2 of those went up to see the 2-3 shift. Best I can tell its a stock trans and stock torque converter. Appreciate any help.
Fill it until fluid level shows full. Running in park. Then go 1 qt over full.
If you still have issue, prepare to spend for a rebuild.
Sorry for your luck
I'm just in the same process on a brand new transmission because I screwed up on the fluid level. (Don't work on cars when your tired.. TM)
Now I would call for a Priest to come and give "Last Rights" to the Transmission.
I do not really know how badly the Transmission is performing...
But from your descriptions, it sounds relatively bad.
Normally once the Fluid Level has been examined...
I would take Line-Pressure measurements for all the Gear-Selector Positions, at an idle, and at 1,200 to 1,500 RPM
(All Tires on the ground, and with the Vehicle remaining still. Use the Brakes in the Gear-Selector Positions that require it).
If somehow you are lucky, and have good Lines-Pressure readings...
Get a long Hose, tape the Gauge to the Windshield, and monitor the Pressure while driving.
Lastly, you can disconnect the Main Electrical Connector from the Transmission.
Take Line-Pressure measurements again... Line-Pressure should be at the Maximum.
If need be, a Road-Test can follow with the disconnected Transmission Electrical Connector...
The Transmission should operate normally in the Reverse Gear Position...
and should be ONLY operating in 3rd-Gear for Forward movement.
The Transmission has lasted a very long time, and does not owe anyone anything.
Good luck!
Feel better now. Lol
This would be a good project for you and your son to take on. It doesn't require a lot of special tools and with YouTube and this forum to help you along you should have a successful outcome. There a several very good threads on rebuilding the 4L60E in this forum, with tons of great information.
Good luck
Good luck
I wasn't going to harass the builder since it was my screwup. Bought it mail-order, likely would not do that again just so I can install and take it to the shop for function test. , of course now my project has full data on the trans including live pressure so wouldn't likely have the same issue.
$850 for a build would have me running for the hills.
you'll likely be getting a trans that's been clutch slapped and rattle can'd. Not an actual proper rebuild.
The shop that charges 2700 wasn't terribly far off. Everybody thinks these vehicles with 4l60e are old and not worth 2700 for a rebuild...but that's not the case. Figure 2000 for the rebuild and the new tq converter. 500 for R&R. 200 in shop supplies, fluid, etc.
They refuse the job unless they pull/install because they know the average joe has problems just putting fluid in it (as is true with this thread)
So they aren't gonna trust the average joe with removing, installing, getting converter spacing right, flushing the cooler, filling it with fluid, making sure the shifter is adjusted right, making sure the driveshaft and U joints are in good shape, the trans mount is in good shape etc. All the little things that go along with an install.
They've had too many average joes either break the pump with the converter during install, or drive them 4 qts low on fluid, etc and come back. And they know it's just an absolute PITA do deal with a customer who just paid for a rebuild...now having issues...and you get to tell them it's their own damn fault.
And then, charge them full price again to fix it. That's the real stinger. Because my labor isn't worth any less just because the customer screwed up an install.
So anyway, after that little mini-rant
the $850 number is something you should RUN from. I mean RUN.
The 2700 number is a definite blow to the checkbook and I understand passing up that price...but don't act like it's a ridiculous number.
but $2700 is not ridiculous for R&R, rebuild, converter, and a quality warranty.
And as far as the "average joe" comment...to the shop...everybody is an average joe.
They don't care what your history or experience is. There are shops with "master techs" that break pumps and can't fill up a trans with fluid. If they are going to build and warranty something...they're going to see the whole job through and I can't blame them.
I personally will do a "bench job" and let customer do the pull/install. But it is with clear understanding that if they screw it up, that's solely their fault and the warranty is over right then and there. If they want to pay accordingly to fix the screw up, that's fine. But don't expect a warranty repair for your incompetence.
otherwise people would try to save a couple hundred bucks by reusing an old converter.
An old converter full of the old burnt fluid, with a lockup clutch that is nearly worn out already.
Some shops will allow you to supply a high performance converter and they will just not include the converter or any converter caused failure in their warranty.
You've got to understand, these shops aren't doing this job for fun. They don't care if the camaro is worth 1500 bucks or 15,000 bucks. Their work is the same, the warranty will be the same, and they only want to charge according to their work, warranty, risk, etc
Transmission builders are in business to make a living not to cut prices because someone has a crap box project were the trans is worth more than the car. I have a saying and that is if a job isn't making me money I just as well be doing my hobbies.
