quick question about 4l60e pump diagnosis
i wonder how it gained ~1/8" of extra travel?
the other day, before i realized my 3-2 control solenoid and tcc solenoid was popped out (was in limp mode), i was driving it in third gear i think (had the shifter in 4th [OD] and i was going up a hill and noticed i left something on the hood. well i stopped on the hill and grabbed the thing and jumped back in the truck and stuck it back in [OD] and went to climb the hill and after i got most of the way up it seem like the gear was letting loose and the rpms was climbing a little and i let off the throttle and finished climbing the hill. so i might have scortched 3-4 clutches and/or steels. but after i figured out that my 3-2 control and tcc solenoid was popped out, i reinstalled them and put the retainer clips on them and bolted everything back up but still had a bad flare going from 2-3 (shifter in 4th [OD]). but once it was in 3rd it seemed to hold it fine and then shifted to 4th great and the tcc locked up.
i still have not got this thing on the road at all. i knowed i had a bad 2-3 flare, and even though it shifted through all other gears fine... i decided to not drive it at all. today i checked the servo travel and the cover moved ~3/16" so i have way to much travel on the servo and i guess the band is probably releasing to soon or something. the servo pin has 3 rinds on the tip of it so i am not sure if the one from probuilt will be a little longer than this one with three rings. i guess all i can do is go ahead and buy it and hope for the best? what do you guys think?
edit: do you think i could put a shim behind the 4th servo piston? like between the cover and the 4th piston? that woudl reduce travel but i am not sure if it would do any justice
Probuilt is not known for fast shipping, but if you can wait the services that he offers is 2nd to none.
You should open the 3rd feed hole to at least .093.
I called around to half a dozen or so transmission shops on my area, none of them vac tested. none of them had simple things like AFL repair kit from transgo. i guess they just buy reconditioned valve bodies if they have a ”problem” unit (crazy right??). i ended up building my own vac test rig (look for maroonmonster's thread on it) and bought the transgo reamer.
i can't really say much on reusing electrical parts... if I knew they had been replaced recently and were still working i would reuse. high milage or failed unit i wouldn't bother wasting my time.
Ps: i don't know what happened to your servo clearance, this is why we check it with a dial indicator. maybe your band wasnt seated correctly? were all the seals removed while checking (including servo cover)?
but a question.... would a disconnected epc cause low line pressure? or would it default to max line pressure all the time? if the connector wasnt seated on the tabs correctly, then it could be getting an intermittent connection which could have some kind of effect on line pressure?
i got to install the servo pistons ( without seals) with pin (dont know if with or without seals but i will do it without if noone comments otherwise) and cover. but what i am confused on, and its probably because i never used a dial indicator, but i am confused on how to get the reading. am i suppose to install the servo and cover without seals. then position the dial indicator so it reads .075, then press the cover and see if it zeros out? seems like if it travels more than .075 i wouldnt know because it would zero out if there is more than .075. Or do i press it in and try to get the dial indicator to read zero then let off the cover and see what the travel is? i dunno if that would be the best way either though. only other way i know to do it is press the dial indicator into the servo cover to like .250 or something like that, then press in the cover and write down the value then subtract that value off of .250 and that would give me total travel and would eliminate any possibility of a false reading due to the cover traveling further than the dial indicator pin is set at. i guess what i am saying is, the best way in my head is to make sure the dial indicator pin is constantly engaged with the servo cover.
also, when pressing the servo cover in, do i press it in with a lot of force? or would like 10 lbs of force be ok? and again thanks for yalls help this far. hopefully this will do it. if not, i have a machine shop right up the road that told me they would drill out the 3rd feed hole in the separator plate for free. and while i am at it i may get them to flatten the mating surface of the valve body as well to ensure no cross leaks there. hopefully i can get this thing shifting right in the next day or two
it doesn't show it in the pictures, but it comes with orings as well.
i have my little brother on the way with a bench grinder... hopefully i can get this thing set right without taking to much off. i have a welder but i dont want to go that route if possible. once i get it set ill make a video though. will let yall know how it goes.
edit: if this new servo pin and vette 2nd servo piston doesnt do it, then i will order the sonnax boost valve and take my separator plate up to the machine shop up the road. hopefully this servo pin with the seals that seal the pin bore will do the trick, otherwise i wonder if that third accumulator capsule is leaking. if the new servo pin and piston doesnt fix it i will take of the valve body (and go through it myself) and take a small diameter punch and tap the checkball into the seat of the capsule, maybe that will help as well... should have done this to begin with. i didnt check if it leaked because it was a brand new one, but i guess i should have made absolute sure it was seating properly. anyway... i will keep yall updated and again, thanks for the help, it is very much appreciated.
have not removed the valve body yet, was wanting to see if using this vette servo with the pin with seals would fix it. if this doesnt fix it then i will be removing the valve body and seating the 3rd accumulator checkball in its seat a little better. the capsule is in there good but i dont know if the check ball is leaking past its seat. a little love tap with a small punch and a wrench or something would probably seat it lovely. but let me know about that travel.
