quick question about 4l60e pump diagnosis
EDIT: guess it would help if i posted the link as well lol
EDIT2: Actually I think I found the AC Delco upgraded separator plate for 98 K1500 and I am pretty sure it is a bonded gasket separator plate.
Would it be better to buy this or to use original? Mine is going to need the check ball fix that clips into place on 3 or 4 check ball seats
but back on the band clearance/servo pin travel. i have a spare 2-4 servo cover and i think i will knock a hole in the center of it. then i should be able to measure the exact pin travel correct? also @bbond when you say set band clearance to .060 or .070, do you mean to use my feeler gauges and gauge between the reverse drum and band material or are you saying the band clearance IS the servo pin travel? surely the pin travels more than 7 thousandths of an inch? sorry for any confusion
if i cut a hole into the spare servo cover i have, i would measure the pin travel by placing the dial gauge directly onto the pin. and i do not want any more than .060 to .070 (or around 1/16th") of travel before i cannot press the pin any further and the band should be fully seated, correct?
i took a straight ruler and placed it flush on the cover, then stuck feeler gauges in between the ruler and the lip of the case where the servo bore is. i measured .060 here. then i put a bolt back in the hole for the heat shield and stuck my pry bar on the bolt and pressed the servo cover as far as i could (with a bit of force) and then measured .050 in between the ruler and servo cover. so i added the two together and that should give me my overall travel would it not?
i am trying my best to find a dial gauge i can use but so far i havent been able to get my hands on one.... but using my feeler gauges seems to work ok but i am not sure if this is the correct measurements to take. just to reiterate what i did... i measured the gap between the straight edge and the top of the lip on the case where the servo bore is and i got .060. then depressed the servo with force and let the straight edge rest against the lip of the servo bore and measured the gap between the cover and the straight edge which was .050. these added together is .110 give or take a few thousandths. i am doing this alone and there is really no good way to get a picture because both of my hands are occupied. but does this sound like a reliable way measure it? by my calculations, i need a shim that is .050 - .060 thick.
edit: after a little more fiddling (took all the seals out of the servo), the total overall measurement i got with this method... is a travel of about .120". so thats just shy of 1/8". so if i need to get it down to a travel of .060 then i need a shim that is .060 thick
so i guess the question is, do you guys use washers and orings underneath the pump to case bolts? or is an oring without a washer just fine?
but all i like is torquing these bolts to 18-20 ft lbs once i get the orings, and then put the bell housing on.
So pump gasket or no...you can still have leakage
the o rings need to be used on the proper bolts and they are to be used alone. No washers. No rtv. Etc
Just clean and nice hardware and pump face
hmm but now that i think about it, there are 5 of the thicker orings so i wonder if those should have went on the manifold pressure switch... any one know for certain?
bolt and orings for comparison
picture of the thicker oring
thicker oring put on bolt
regular oring put on bolt
edit: hahaha, i had it in park lol. it was wild because i turned it a little and heard something click inside. must have been park engaging into the park pawl engaging. i shifted it to nutral and it turns as it should and i can hear the lo and rev clutch support inner race screeching nicely. so let me torque the pump bolts down and check end play and then all i got to do is put the bell housing back on! well, and then cuss it back into the truck ofcourse.
edit2: torque down pump bolts and have .018 - .020 end play. measured it 3 times. i am hoping that i will get it back in this week. will update thread with results
when i put it in the truck, ill jack the back tires up off the ground, then ill pour 5 quarts in and crank it for 4 or 5 secs. then pour 5 more quarts in and crank it up and let it start warming up. about 10 secs after i crank it, ill pour another quart in it and then get in it and go through the gears. once its warm and gears are engaging, ill lower the jack and check the fluid. but i need to know where to mark the dipstick. i marked it but i just want to be sure its right
