quick question about 4l60e pump diagnosis
also, i need someone to look at this torque converter hub. i will take a pic shortly and post it. i would ask someone local but there are no local trans shops around. i live in a small town and the only tranny shop went out of business due to people having trouble with their trannys
its hard to get a good view of this on any video ive found so i reckon i will stop right here for the evening and await someone guidance
edit: ok i think i have come to the conclusion that trans bench was using a different race in the lo and reverse clutch support assembly which looks to sit lower in the clutch assembly. is this corret? should mine be sticking up about 1/8" - 1/4"?
but yeah, i made me a little spring compressor tool out of an aluminum camper shell clamp and a threaded rod. works good but it is a little hard to get it lined up. anyways, i will post more pics shortly
i got lo and rev all done and put the sun shell and all, and then i went into assembling the input drum clutches with the new pistons i bought. well after 3-4 hours, it turns out i forgot to put the forward clutch housing in there as well so my clearances for the forward clutches was coming up way short. then after another hour of me questioning my very own existence, i installed the clutch housing and assembled the overrun, forward and 3-4 clutch packs. the forward and 3-4 clutches were larger than the expected clearances, but after the day ive had, i just assembled it and got the reverse input drum installed on the input drum and proceeded to lower it into the case. after 3 or 4 mins, i had it bottomed out, top of reverse drum was below the pump/case mating surface. i went ahead and practiced putting the band on as well, though i think i have another problem though i dont think it is really a big problem but i will explain tomorrow with better detail when i take it all back out to double check my input drum clutch clearances and adjust somehow if i need to. its beer thirty for me. and as always thanks for yalls guidance and help
edit: i did measure the clearances for the forward and 3-4 clutches and both were on the larger side. like larger than spec possibly. the forward clutches are hard to get an accurate reading on but they are about .050 - .055 i think and the 3-4 are almost .070. both could stand to tighten up a little. but i will get better measurements tomorrow. i will most likely be completely disassembling it again just for practice assembling it. every time i go back and redo it, it gets easier and easier to remeber how and what goes where.
forward clutch: .043-.045 (atsg doc says .030 - .063 is normal)
3-4 clutch: .070 (atsg doc says .035 - .083 is normal)
reverse clutch: .060 (atsg doc says .040 - .076 is normal)
all of these measuremenet were taken with soaked clutches and i had air tested the pistons and seated the clutch assembly. do you think my clearances are normal for used clutches and steels? maybe the used clutches are "broke in". i wonder if i could tighten up forward and 3-4 clutches. 1 extra steel plate will put me above tolerances though
also, the other problem i were talking about is.. if i put the sun gear (i think it is the sun gear that unions the forward sprag and the input carrier) in the input carrier, i can turn it both ways and the sun shell will spin. but if i grab the outside of the input carrier and turn it counter clock wise, it locks. if i turn it clockwise, it will turn, sometimes faster than i am turning the input carrier.
my question is, how fast this sun shell turns is not predictable. sometimes it will spin faster than i am turning the input carrier, sometimes not. does this mean that my lo and reverse clutches could be bad? i realize that after the tranny is put back into the truck, the lo and rev piston will apply, but i am unsure about this unpredictable behavior.
also, i am eye balling this but want to get someones opinion before i pull the trigger and buy it. mainly because it has this "BAN" wording. if it is remanufactured, i wonder if BW themselves did it or if it is some cheap knock off counterfit? please let me know and thanks ahead of time.
As for the band I have no idea what the "BAN" stands for.
As stated in the product description, it is lined with High Energy material. Yes, is an authentic Borg Warner product. Please do not expect it to be individually boxed as we buy these products in bulk. Thank you for your inquiry. See attached picture.
EDIT: order the band and also a new neutral safety switch. everything should be here by the 4th. will update thread when everything arrives
so looks like it will work and the alternate part numbers match other known part numbers that will work with my model. i am not sure if there is a specific band for LS style trannies and a different one for LT style, but in my head it seems like all of that would be the same regardless of it being LS or LT.
one other thing is, i need to disassemble the input drum one more time i guess. when i apply air for the forward or overrun piston and then let the pressure off, i get this sound like it is dragging or something so i def need to disassemble that and check it before i install it permanently.
also, the pump i am using is from the spare transmission. the inside where the rotor and vanes run looked a little better and the stator shaft/reverse drum bearing landings looked much better than the original one. it did have some rust on it but i took some scoth brite and tranny fluid and went to town on it. you can still see some discoloration but it is smooth. do you think it is ok to use this like this? ill post some pictures if needed.
also, on a side note that has nothing to do with this tranny but it is about my health. i think i just figured out what is wrong with me. my ex girlfriend told me very serious one day that she poisoned me with boric acid (the stuff that kills fleas) but she is a habitual liar though and you could never get the real truth out of her. but i got to looking for some hose clamps in my cabinets and found big clear pickled egg jar that had some some older electrical stuff (outlets and switches and covers and screws etc) i had stored in it a long time ago... but on the very top of the jar was elemental mercury that my mothers ex boyfriend used when he was mining gold. (my mother passed away a while back and he left and left all his stuff). i had put the mercury up a long time ago and it was no where near this jar and should not have been in this jar much less sitting at the top. so it seems she was poisoning me with elemental mercury. i am having severe weakness, slow reflexes, my memory is toast, and i have a lot of wide spread nerve pain and other neurological symptoms. sometimes it will feel like a bolt of lightning shoots up my backbone... most of the time it is when i am just about to fall asleep and i get these severe shocks. its crazy and i cannot believe i think i have finally figured out what the problem is with me. the doctors have all been looking at me like i am crazy. boy wait till my doc hears this. she really going to think i done fell off my rocker. but man, i have problems speaking most of the time. i forget what i am talking about as i am talking. my messages at this board probably all look like i am demented but i am not, luckly i can reread these messages before i post them (if it does any good haha). sorry for the extra irrelevant info but i have to get this off my chest because i am pretty sure this is what i am suffering from. and if yall knew my ex gf then you would all think the exact same thing. she was crazy af but when we went to see family or friends she would always seem just fine. even my sister told me once "i dont know what your talking about, she seems like a cool person" and to which i responded yeah well you dont have to live with her. dudes, i am astonded that i didnt wake up with a knife being shoved through my chest. this girl would have full fledge conversations with me while i was asleep and the only reason i know is because i woke up during her doing it multiple times. then once i figured otu she was doing it i started recording it. this girl would be tripping so hard that she would think that i was getting up out of bed and going to meet some chicks WHILE SHE WAS AWAKE AND RIGHT NEXT TO ME seeing my every move. she was bonkers and i am glad i got out alive. worst part about it is i havent told yall nothing to bad yet lol. but yeah, i think i finally figured out what the problem is with my health. sorry for the irrelevant info
i will post pictures tomorrow of the stator shaft teflon seal and bushing seats/landings. i am pretty sure it is ok, the one that was in the truck i am positive that one is bad. but ill take pics of both tomorrow and upload them
And this is the original one that was in the tranny. the bushing seat looks wore down next to the pump body right there. and looks overall gauded i think. does not look like i can reuse this.
if i need to take better pictures just let me know. the "good" one looks pitted but it is smooth enough that i cannot catch a nail on it. i will probably get at it with some more scotch brite. but let me know what yall think. i also think i may have compressed the teflon seals on the stator shaft a little to much. they seal and it seems to check out when air testing, but i do not have to give extra effort to pull the reverse drum off the pump, so maybe i might have compressed them a little to much with the hose clamp. i think i will try to redo them but with electrical tape since the other teflons on the input shaft seem to have sealed great
