Goddammit - another 4l60 build
Both pressure regulator valves tested at 11-11.5" hg.
However, I am using a rental vacuum pump, which is rated for 1.8 cfm, not the 3+ cfm that Sonnax recommends.
I'm sorry if this is a stupid question, but do y'all think that is the issue? Because that would be a huge amount of leakage, and none of the clutches were smoked.
One valvebody was absolutely wrecked; I got some reading of 0 in/hg on a couple of bores! As they say in Spanish, it is el fucked-o.
The other one was much better, but some of the valves/ bores are borderline, in my opinion. I'd like y'alls' opinion of them.
Pressure regulator valve: 11" hg. I know this is really bad; should I bit the bullet and ream the pump, or find another pump?
3-4 shift valve: 11" hg on the end closest to the end-plugs, 22" on the end near the center of the valvebody.
4-3 sequence and 3-4 relay valves: 13" hg
TCC regulator valve: 14.5" hg
AFL Valve: 18.5! Guess I won't be needing that Central Valvebodies AFL valve after all!
Accumulator valve and sleeve: 12" hg
2-3 valve: 19-20" hg
1-2 shift valve: 20" hg
Low overrun valve: 16" hg
Forward abuse plug: 18" hg (Guess I don't need the Sonnax abuse plug/ valve kit, but I'm going to use it anyway.)
Forward abuse valve: 13" hg
Reverse abuse valve: 16.5" hg
Reverse abuse plug: 15" hg
I didn't test the 3-2 valves, because I'm blocking those; I also didn't bother to check the TCC valve, because I'm using the O-ringed Fitzall valve.
Also, I forgot to check the boost valve for some reason, and I'll check back with results tomorrow.
I would still install the CVB AFL valve......
And I would look for another pump and/or have it reamed if it was me.
Also, does anyone know what Sonnax's specifications are? I looked through their site, and I only found the test locations, but no real specs.
SURPRISE!
It leaks a ****-ton - 10"/ hg.
So I'm going to need a Sonnax boost valve, but I've got a question:
What is the difference between the ratios that are listed?
Sonnax lists a "Standard OE ratio" and "Large OE ratio."
What will this affect?
Also, just so we're all clear about the parts/ numbers, I'm talking about numbers 77898E-14K (Standard), and 77898E-16K (Large).
SURPRISE!
.472 diameter
The p/n you have listed are both for a "late" pump aka a pump with Input Speed Sensor
If you do not have ISS
Then you will need a different boost valve
If you DO have the late pump...I recommend the .472 variety.
However, I think I have the right part: 4L60E-LB1, the 1.9" valve.
This is what came out of the pump:
This is the valve that came out of it:
If you want the part number off of the pump, I can get that.
In other news, I bought a big-boy vacuum pump; gone are the days of me paying a guy $30 to vacuum and recharge A/C systems for me!
I'll be dropping off my pump to get reamed at a shop in the "transmission district" probably some time next week.
Stay tuned for the latest test results.
Sometimes, well, MOST times, I really hate where I live. For the past two weeks, I've been trying to find a local transmission shop with a reamer for a Sonnax oversized pressure regulator valve, and THREE of them have said that they had it, only to find out that once I show up - SURPRISE! - they don't actually have it!
It turns out that they didn't even know what the tool/ part was (this tells you a LOT about the quality of transmission repair in my area).
It doesn't help that most of the people working at these shops can't/ won't/ can barely speak English, and my Spanish is admittedly not great.
So I bit the bullet and bought the #77917-TL from Jeg's, on sale for $99.
Anyway, here are the vacuum results with the new valves/ plugs installed:
3-4 shift valve: 18" hg on the end closest to the end-plugs, 22" on the end near the center of the valvebody.
4-3 sequence and 3-4 relay valves: 20" hg
TCC regulator valve: 14.5" hg, still the same
AFL Valve: 21" hg
Accumulator valve and sleeve: 19" hg
Forward abuse plug: 21" hg
Forward abuse valve: 16" hg
Reverse abuse valve: 20" hg
Reverse abuse plug: 24" hg (!)
Question: As y'all can see, the TCC regulator valve was not changed, and it's results are at the borderline of what is usable.
Do y'all think that the combination of me using the Fitzall TCC valve, the oversized Sonnax boost valve, and the freshly reamed Pressure regulator valve will provide enough line pressure to cover for the loose-ish TCC pressure regulator?
I really don't want to buy ANOTHER special Sonnax reamer kit that I probably won't use again for a long time.
I ordered this valve a long time ago, and it says that it's for '04- up transmissions WITH CAN bus.
The engine/ transmission I'm using is from an '04 Tahoe.
Which one should I use, and what are the consequences if I picked the wrong one?
