Goddammit - another 4l60 build
Sonnax Part No. SWAT-P1
I'm still going to run it.
Here's how it looked while I was testing it; maybe MaroonMonster, Vortec, or someone else can point out if I'm doing something wrong.
Was just asking is all as bbond mentioned it still seemed a little low as those kits really improve things from what I have experienced.
The vacuum testing is a very useful topic which has only been discussed here starting recently.
If anyone is up to it, please create a list of links to the Sonnax (or other) pages which show exactly where and how to vacuum test each circuit in the valve body.
I found this: https://www.sonnax.com/tech_resource...uum-test-guide
But is there more?
Also, I see that the Sonnax VACTEST-01K vacuum test stand is listed on Jegs for only $157 but has a 1-month shipping delay. Summit has it in stock but at $248.
Harbor Freight has a 3CFM vacuum pump for $150. (But its their cheapo Pittsburg brand.)
DIY Vacuum Test Valve Body - LS1TECH - Camaro and Firebird Forum Discussion
Also check out this video
Jegs has the Sonnax 77754-VTP 4L60 Vacuum test plate for the 4L60e for $123. It’s not a necessity but it looks like it would make the job easier.
In other news, I got the Fitzall A74741QA. Here it is next to the A74741QB, in case anyone else is as confused as I was. ("B" on top, "A" on bottom)
I've got good news and bad news about the vacuum test results:
The result of the passage CLOSEST to the edge of the valvebody was 24"! I guess the O-Rings will do that for you.
Bad news: The results for the inner isolator valve were somehow WORSE than the initial test: 11.5" was the best I could get, and I was screwing around with this thing for awhile to optimize the reading. I have no idea how I got the 14.5" number the first time.
Here's a picture of the passage I tested, in case anyone has any criticisms:
Question 1: Since I really, REALLY, REALLY don't want to buy another special Sonnax valve, plus tools that I will probably only use once, is there any way that this could be passable? I really tightened up one side of the circuit.
Question 2: Since the Fitzall TCC valve pretty much blocks the isolator valve inward, is there any way that using some kind of sealant on it could be feasible?
Or what if a groove was cut into the Isolator valve, and an O-ring installed?
How do the pros out there handle this situation?
Maybe Maroon or Vortec can school my *** on this.
Last edited by dixiebandit69; May 26, 2022 at 05:37 PM. Reason: Spelling. I sounded like Mario for a second.
or when flipping the stock valve setup around for "on/off" lockup
it will just leak the TCC PWM signal oil to exhaust. It's an orificed and pwm controlled leak so it won't be enough volume to matter at all.
I used some Caterpillar No. 46 hydraulic oil for cutting fluid. It went pretty easy.
Results: 21.5" hg, a solid 10" improvement!
If you had told me ten years ago that I would be getting excited about vacuum readings, 1) I wouldn't have known what the hell you were even talking about, and 2) I wouldn't have believed you.
