Trans cooler help
Old May 11, 2022 | 08:10 PM
LSdominator88's Avatar
Default Trans cooler help
I need some advice on picking a transmission cooler.
My needs aren't complex; it's a stock '06 Silverado, 5.3 2wd.
Basically, I want the biggest, most badass cooler I can fit, but I don't want it to cool the fluid too much, either.
I've heard about aftermarket thermostats to control the temperature, but the external ones seem too complicated, and the coolers with built-in thermostats only have barb fittings, and I heard those can make my truck explode.
Is there any way I can put a thermostat inside the transmission pan?
This thermostat is for an '06 Silverado, and I think this will fit inside the pan, and won't interfere with the lines:
https://www.oreillyauto.com/detail/c...ado-1500?pos=1
While I'm on the subject of cooler lines, steel lines are way too hard for me to bend, but I don't want to use any type of hoses; they might get tangled around the intake and choke off the air supply.
Does anyone make a product that could teleport the fluid into the cooler and back to the transmission? That would save a lot of problems.
Also, I'm on a budget; is there a place where they are giving this stuff away for free?
Thank you all so much.
Old May 11, 2022 | 08:53 PM
theunderlord's Avatar
Old May 12, 2022 | 07:08 AM
2BFAST's Avatar
Facepalm
Old May 12, 2022 | 07:23 AM
MaroonMonsterLS1's Avatar
@matermark made a new account? interesting
Old May 12, 2022 | 02:58 PM
matermark's Avatar
Sorry, but it's not me.
I'm glad you have such a fascination with me though... you even tagged me. Don't know what that means but I'm impressed with your forum skills!
Old May 12, 2022 | 04:17 PM
Not sure who this is
but A+ on the trolling.
I thought it might have been matermark making fun of himself but I guess it's someone else teasing him
@mrvedit while the post would probably be funny...probably not productive for the forum
Old May 12, 2022 | 05:24 PM
01CamaroSSTx's Avatar
You're either off your rocker or blowing smoke because there's no such thing as free these days.
Old May 13, 2022 | 02:27 AM
matermark's Avatar
Shady Grady at it again?
Old May 13, 2022 | 07:43 AM
mrvedit's Avatar
Moderator
As a quick search will show definitive options, parts and discussion on external transmission coolers, I am closing this thread.
While a question about putting a radiator thermostat inside the transmission might be funny on April 1, or sending your kid to the parts store to buy blinker fluid and a transmission thermostat, it serves no educational purpose here.
If you guys think I should just delete this post, I will be happy to do so.
BTW - I'm having a private conversation with matermark and I will help him find the info he needs without the "trolling" posts.
