4l60e no reverse after rebuild
Old Jul 25, 2022 | 06:59 AM
Kmullins's Avatar
Default 4l60e no reverse after rebuild
I have a 95 trans am with a 4l60e that blew out 3 4 clutches I rebuilt the transmission put it back in and now no reverse. I have taken the trans apart 3 times now in the last 2 weeks and can’t find anything wrong. Nothing is broke and looks as it should as far as I can tell. Yes it has enough fluid in it new filter and seals. It had reverse before I tore it down. A couple of odd things are if I put in neutral and try to move the wheels they will only go forward and not backwards. I also tried to scan it and kept saying fail. My scanner will read the obd1 codes. I didn’t mess with the pump or the valve body.
Old Jul 25, 2022 | 11:55 AM
bbond105's Avatar
Did you replace the teflon rings on the pump and air check the reverse drum with it sitting on the assembled pump with new sealing rings?
Old Jul 25, 2022 | 12:27 PM
Kmullins's Avatar
I did replace the Teflon seals but I didn’t air check it.
Old Jul 25, 2022 | 06:24 PM
tayto's Avatar
https://ls1tech.com/forums/automatic...o-reverse.html
Old Jul 25, 2022 | 07:07 PM
bbond105's Avatar
You can take your car for a test drive and pull the shifter all of the way down to manual low and verify that you have engine braking. If you have engine braking the low reverse clutches are working.
Old Jul 25, 2022 | 07:58 PM
Kmullins's Avatar
I would take it for a test drive but it will not roll backwards in neutral to get it out of my garage I have it in the air and I can’t turn it by hand while it’s in neutral. It’s almost like it’s locked up. I wonder if some how something is backwards I honestly don’t know. When I shift it to reverse it sound like it wants to go in reverse but it doesn’t move. I’ve let it sit and run in drive for about an hour and still no reverse. The reinforcement plate is tight. I never took the boost valve out.
Old Jul 25, 2022 | 09:57 PM
tayto's Avatar
Read this, sounds like you could have valve body bolts in the wrong spot ....
​​​​https://ls1tech.com/forums/automatic...erse-bind.html
EDIT: i would pull 1 bolt at a time, check to see if the car rolls in reverse and then reinstall that bolt again vs dropping the whole valve body.
Old Jul 26, 2022 | 03:41 PM
Kmullins's Avatar
I will definitely check the bolts.
Old Jul 26, 2022 | 06:28 PM
vorteciroc's Avatar
The wrong Valve-Body Bolt could be the issue...
It is usually an issue in the Manual-Low/ 1st-Gear Position also.
Does the Manual-Low/ 1st-Gear Position operate properly?
If not the Bolt, then continuing on...
Pressure in the Manual-Low/ 1st-Gear Position?
Pressure in the reverse position?
If everything looks good for the Manual-Low/ 1st-Gear Position...
Then something in regard to the Reverse-Input Circuit would be an issue.
Was the Reverse Input Drum replaced?
The wrong Version of the Reverse Input drum can cause a restriction.
Wrong Valve-Body Gaskets, wrong Separator-Plate, Check-Ball in the wrong place...
Time to do some digging!
Old Jul 26, 2022 | 09:36 PM
Kmullins's Avatar
It is fixed. I want to say thank you to you guys for your help. It was one 10mm bolt I had switched with an 8mm bolt on the valve body.
Old Jul 26, 2022 | 10:07 PM
vorteciroc's Avatar
We can thank Tayto and Bbond for the quick thinking on that one!
Old Jul 27, 2022 | 09:32 AM
bbond105's Avatar
Tayto is the one who hit the nail on the head or should I say bolt on the head.
