Blocking 3-4 accumulator 4l60e
Old Oct 10, 2022 | 07:28 PM
skinumback's Avatar
Default Blocking 3-4 accumulator 4l60e
I have researched the threads on here and noticed a lot of builders say to block the 4th gear accumulator and leave out the piston and spring. My question is do you also leave out the check ball that is in the case beside the 4th gear accumulator housing or the one that is on top of the plate or do you leave them in place? Thanks
Old Oct 11, 2022 | 12:55 AM
bbond105's Avatar
Plug this hole and leave the #1 check-ball out of case.
Last edited by bbond105; Dec 9, 2022 at 12:23 PM. Reason: Mistake on numbering check ball.
Old Oct 11, 2022 | 09:23 AM
skinumback's Avatar
Originally Posted by bbond105
Plug this hole and leave the #6 check-ball out of case.
thanks, I’m assuming #6 cb in the case is the uncaptured one beside the accumulator bore. Is that correct?
Old Oct 11, 2022 | 11:27 AM
bbond105's Avatar
You are correct.
Old Oct 11, 2022 | 11:49 AM
skinumback's Avatar
You are correct.
thanks
Old Oct 11, 2022 | 04:00 PM
2BFAST's Avatar
Also the cup plug with the small orifice in it, make sure its free and clear. Take something and poke through it to make sure its clear.
Old Oct 12, 2022 | 12:07 AM
skinumback's Avatar
I will, thanks for the advice.
Old Oct 14, 2022 | 02:08 PM
jakeshoe's Avatar
Doesn't matter when you're killing the oil feed to it as instructed here.
Old Oct 14, 2022 | 10:06 PM
vorteciroc's Avatar
With the 4th Accumulator Piston and Spring Omitted...
The "Orificed Accumulator Fluid" (Green Colored Fluid in GMPT Manual) will full-time feed that Orificed Cup-Plug in the Bore
instead of "4th Signal Fluid"/ "Servo Feed Fluid"/ "3-4 Accumulator Fluid" (Red Colored Fluid in GMPT Manual).
Old Dec 4, 2022 | 10:01 AM
Dian's Avatar
i (believe) i understand what blocking the accumulator does but have no idea whats needed to do it. can it be accessed with trans in the car?
Old Dec 4, 2022 | 10:29 AM
tayto's Avatar
yes,you will have to remove valve body
Old Dec 4, 2022 | 10:56 AM
Dian's Avatar
is that the case when blocking the 3-2 downshift and the 3-2 control valve also? maybe i find some vids on how to remove valve body.
Old Dec 4, 2022 | 12:56 PM
tayto's Avatar
yes.... pay attention to the v/b bolt length when reinstalling. transgo's shift kit instructions have a good diagram, they are available on their website.
Old Dec 4, 2022 | 02:26 PM
bbond105's Avatar
Old Dec 9, 2022 | 07:37 AM
2BFAST's Avatar
To be clear, wouldnt the 4th accumulator check ball be #1 check ball? #6 would be the overrun ball one would leave out IF one installed the HD 2-3 Shift Valve.
Old Dec 9, 2022 | 12:22 PM
bbond105's Avatar
You are correct. My mistake. I corrected post #2 to say leave out the #1 check ball.
Old Dec 15, 2022 | 02:24 AM
Dian's Avatar
thank you. i found good instructions on valve body removal here (maybe it helps someone):
Old Dec 20, 2022 | 01:47 PM
LS299S10's Avatar
If you block the feed hole in the case and leave the piston out what is the benefit in leaving the checkball out? I left the checkball as it was.
Old Dec 20, 2022 | 01:57 PM
2BFAST's Avatar
Its pretty much useless at that point
