4l80 cooler line pressure
Old Nov 19, 2022 | 05:38 PM
badass68's Avatar
Default 4l80 cooler line pressure
I did the tcc mod as vorteciroc explained in a previous thread. I’m seeing 20psi cooler pressure cruising unlocked, locked and spooled up on brake. Is that low enough to cause converter slip?
I know th400 with dump valves effect the converter under 40psi
Old Nov 19, 2022 | 06:27 PM
Tranzman's Avatar
I would have to say Yes. Not really sure what a 4L80E should have for cooler flow. I hooked my transmission pressure gauge up to the return cooler line after my LS swap with a 4L60E. My 4L60E has a 40-100psi so far. I haven't been able to drive it while monitoring it.These are just readings I've gotten from just running the engine.
Old Nov 21, 2022 | 08:05 AM
MaroonMonsterLS1's Avatar
elaborate on the mod you did.
Where are you measuring the pressure
and what are you using to monitor the pressure?
Old Nov 21, 2022 | 08:56 AM
badass68's Avatar
Update- I was measuring the wrong port. 🤦🏻‍♂️
All good now. 40 with epc 125 line and 50 at max 200 locked and unlocked.
The mod consists of grinding a land off tcc valve and plugging regulated apply.
Old Nov 21, 2022 | 12:21 PM
truckdoug's Avatar
kinda like lonnie has you do it but also block regulated apply? interesting.
probably not gonna wanna lock the converter on the dyno in that config
Old Nov 21, 2022 | 01:44 PM
that is half the mod
if that's the only half that's been shared, the results you're seeing are to be expected
what else did you do to the pump?
Old Nov 21, 2022 | 08:05 PM
badass68's Avatar
.073 line to lube
rounded leading edge of crescent
outer gear pocket
Old Nov 22, 2022 | 07:54 PM
badass68's Avatar
Feel free to tell us the other half of the mod. Kind of the point of forums. Help each other out. 😁
Old Nov 24, 2022 | 01:49 PM
rpturbo's Avatar
Maroon monster definitely shares tons of mods and info. He probably has posted it before, but it does get hard to keep track of all the mods, and where to find them. A buddy of mine has a whole folder we put together on the few builds we have done.
