View Poll Results: Will this work
Will it work
2
66.67%
Or will it not work
1
33.33%
Voters: 3. You may not vote on this poll
Question
Old Dec 13, 2022 | 10:29 PM
ThatredSilverado's Avatar
Default Question
Hey everyone so I have a 2000 chevy Silverado 1500 4x4 and the 4l60e recently just went out only left me with 1st gear Ik someone who has a 98 4l60e that came out of a Tahoe it was 4wd and had the electric 4wd just like my truck I was just wondering if everything would match up I’ve done some research it says it will but I would have to use my torque converter please help
Old Dec 13, 2022 | 11:17 PM
Tranzman's Avatar
Short answer; NO
Long answer; 2000 Siverado 4.8L/5.3L has a Gen 3 LS based engine. The 98 Tahoe had a 5.7L gen 2 engine. the LS uses a top center bolt that does not exist on the 98 unit. Also the LS unit is 5/8" longer than the 98 unit. There will be a lot of driveshaft work to install it into a 2000. You would also have to get a flywheel & spacer. It will cost as much or more to swap it than it would to buy a one that fits. Just a little more to get it built right...
Old Dec 14, 2022 | 09:37 AM
Originally Posted by Tranzman
Short answer; NO
what if you switch bell housings from the 2000 trans onto the 98 4l60e
Old Dec 14, 2022 | 10:28 AM
bbond105's Avatar
​​​​​​​Still won't work. Input shafts are different.
Old Dec 14, 2022 | 10:58 AM
​​​​​​​what if you take input shaft out of 2000 trans and put in the 98
Old Dec 14, 2022 | 11:39 AM
bbond105's Avatar
The input shaft is pressed into the input drum. To remove the input shaft, it will require partial disassembly of drum and transmission at this point you may as well just rebuild the transmission.
Old Dec 14, 2022 | 12:51 PM
MaroonMonsterLS1's Avatar
what if you rebuild the 2000 trans and then just drive it
if you're going to swap input shafts...the thing is already gonna be halfway apart
so just fix it and drive it
Old Dec 14, 2022 | 01:46 PM
that’s the problem I don’t know how to do that and money is a little tight with my truck being down and no transportation to work
Old Dec 14, 2022 | 08:28 PM
Tranzman's Avatar
There is a lot more to changing over A 1998 transmission to a 2000 LS style.
I understand how tight money can be... I've been there done that, now I'm retired...
The pump is different, The input drum is different, well at least the input shaft is. Changing the shaft requires a press & some way to hold/support the aluminum drum, that way you don't break it in the press. The bell housing is different.
Bottom line is it will cost almost as much to swap the items over as it would cost to fix it.
If you have enough experience to swap all that out, you have enough experience to fix the Silverado unit... You have to break it down 3/4 of the way. If your that far in you would be a fool not to at least change all the seals in the low/reverse clutch. When that is is out you have a bare case...
I've done used clutch transmission job's before, problem is they just don't last. Then your doing it all over again...
Old Dec 19, 2022 | 09:43 PM
Default 4l80e swap
So what year model 4x4 4l80e’s can go in a 2000 Chevrolet Silverado 1500 4x4 looking for a little bit stronger transmission 4l60es we’re really bad trannys and what would I have to change in order for that to happen and work or is it a simple bolt up just like the 4l60e
Old Dec 19, 2022 | 11:02 PM
Tranzman's Avatar
None 4L80E's are longer. You will need both drive shafts re-worked, different cross-member, different wire harness, different TFC, different PCM or segment swap.
I disagree on the 4L60E being a bad transmission. if you take the shear #'s that were manufactured. Your going to see a bunch of common failures. If you do a 4L60e right and treat it fairly you'll get a lot mileage.
I built one for my son's 2000 Yukon XL 5.3L. He towed a dual axle trailer quite regularly moving cars and trucks to and from. he even pulled 3500 series trucks with it. It was a solid transmission for over 50K. It developed a miss-fire he couldn't find and eventually took out the TCC lining. It's still used as a back up vehicle... I told him to limit hi-way driving until fixed. You know kids, they never listen...
He did finally find the miss-fire, cracked plug. He didn't think that could happen after only 25k on new plugs and wires.
Old Dec 25, 2022 | 09:51 AM
What year 4x4 4l60e’s can go in a 2000 Chevrolet Silverado 1500 z71 4x4 and what can they come out of like can they come out of a tahoe or suburban or sum or does it specifically have to be out of a silverado
Old Dec 25, 2022 | 10:19 AM
BigBlackCamaro's Avatar
Buy one of these, bolt it up and go.
Then post back about what could be wrong with the replacement transmission because it doesn't work either
Old Dec 25, 2022 | 10:23 AM
'99 to '05 trucks with a 4L60E and 4.8, 5.3, and most 6.0's
Tahoes, Suburbans and vans switched over to ls engines around in 2000. 2003 for vans.
The main problem is, how do you know the replacement functions properly....
Old Jan 27, 2023 | 06:07 PM
Default 2000 Chevrolet Silverado 1500 neutral safety switch
Truck will not turn over my 4wd dash where the buttons are the neutral light is red my truck will not turn over what could be causing this to happen please help
Old Jan 30, 2023 | 10:22 AM
shakenfake's Avatar
Time for a civic!
Old Jan 30, 2023 | 01:08 PM
sounds like stuff isn't plugged in
