4l60e losses all gears until restart
Moderator
Many (too many!) quality parts are made in China by US/Euro companies, but they at least try to maintain high standards and inspect samples.
Its the "clones" made by Chinese owned companies that are often shoddy and dangerous.
Unfortunately some of the auto parts sold even on Amazon under a brand name turn out to be inferior clones. Walbro fuel pump come to mind.
My 01 suburban will lose all gears. I shut off and restart and can drive a mile or so the the truck acts like the traction control is kicking on then won't shift and has no reverse. I can Shut if off and restart it and it will drive fine then does the same thing over again. Do I need to replace trans or the electronics.
Fixed a customers unit today. 03 h2 hummer. Complaint was no movement when warm. Pulled pan had metal shavings in it. Most likely torque converter issue. Customer said try quick easy gix route for time being. So new filter and 5qrts of fluid. Shifts like a dream. Filter and fluid fixed it!
The following users liked this post:
MaroonMonsterLS1 (05-11-2023)
Same problem exactly I’ve been tryin to fix this for 5 years short of swapping tranny
same exact problem not many other people have this issue. Could be pump or torque converter I suppose. Has intermittent whiney noise. Anyone know the cause of this I’m desperate to know. I have a tranny waiting to go in. Should just do it. Doner tranny has its own issues and me broke as ***.
