700r4 -4l60e pump
Old Oct 29, 2023 | 06:00 PM
vorteciroc's Avatar
Originally Posted by dixiebandit69
What kind of spring did you use? I recently installed a Sonnax boost valve (777917-500), and I was not pleased with the pressures I got.
https://ls1tech.com/forums/automatic...l#post20503877
Frank is talking about the Small Boost Spring...
Not the Line Pressure Regulator Main Spring.
The TransGo Line Pressure Regulator Main Spring has been okay...
Other Guys here purchase Springs from "Lee Spring" and "Grainger".
