4L80e NO 4th/OD
What I did find was that the Sonnax 1-2 spring was much weaker then the OEM spring. Everything else I could test looks good; lip seals on piston and bolt air checked fine, shift solenoids and lock-up work in other gears...etc. No codes. Scanner shows 4th gear commanded. Here are the 1-2 springs, with OEM on the right;
I believe this weaker Sonnax spring to be the culprit. Does anyone have any other insight/thoughts before I assemble the unit and test it? I have a lot more experience with the 4L60e then the 4L80e.
The Sonnax 1-2 is a 1.25" spring and the 2-3 is 1.69" and they have worked well for me in the past.
ask for (this is my bare minimum) rostra harness, pressure switch, rosta or toledo drivetrain for on/off noids (a&b) and borg or delco PWM noids
good luck yall
good luck yall
