Helpful automatic transmission information for GM
Band release - .104"
Rev input - .104"
3-4 clutch and 3-4 clutch signal - .110"
1-2 shift - .096"
2-3 shift - .140"
3-4 shift - .110"
Low/reverse - .093
Forward clutch - .086"
I do like the extra sealing rings with the Sonnax pistons as well as the rings on the servo pin.
No idea then whats wrong.
Maybe Tune?
Rev input - .104"
1-2 shift - .096"
2-3 shift - .140"
3-4 shift - .110"
Low/reverse - .093
If you would be kind enough to name the 2 holes I can go from there
Does B2Fast enjoy a firm to very firm shift and you prefer a slightly shorter shift than OE? I once had an old 76 Le sabre 350 (Buick engine) TH350 and 273 gears. I installed the sk350 box kit from transgo and it would bark the tires on a mid to full throttle shift. Just firm below that and I did not drill any holes out at all. Same kit in a 74 Nova 6-cyl 273 gears and it shifted ok-firm at all throttle settings. I even checked vacuum at the modulator and installed a small modulator. no changes..
He is using a Recipe that I gave to Dana/ PBA many, many Moons ago.
Creates a very FAST 2-3 Up-Shift that can be firm with Throttle (CHUuuuuuuuuurRP!)
The world of the whole drivetrain planning is somewhat new and confusing for me. I dont even know where to start hahah.
My Specs :
Im 4700 LB weight
Rear end 3.73
Stock Stall
Wheel size 33" BFG AT 285/70/17
1-2 - .074
2-3 - .135
3-2 - .135
3-4 - .110
BR - .101
FwD Clutch -stock
Lo/Rev - .Stock
Rev - stock
Super servos harsh for my application.
After i lifted the truck and put on 33's, it became slooooow
Does 2bast enjoy a firm to very firm shift and you prefer a slightly shorter shift than OE?
Its def not a hard shift at WOT but its fast and holds no doubt. Part throttle, its a nice little bump thats quick. Thats the best I can describe it but its far from harsh
My Specs :
Im 4700 LB weight
Rear end 3.73
Stock Stall
1-2 - .074
2-3 - .135
3-2 - .135
3-4 - .110
BR - .101
FwD Clutch -stock
Lo/Rev - .Stock
Rev - stock
I am assuming you used wide band in the build and the sonnax servo which should only yield a firm but not overly aggressive 1-2 shift and have little effect on the 3 or 4 shifts.
I have ,092 on all mine in my own trans with the same servo and wide band for 2nd and .100 on the other gears, My shifts up and down are not overly agressive at all under part throttle and perfect at WOT. I do, however, have a 2800 stall. I think a lot of the difference is the stall as far as the 1-2 higher stalls act as basically a cushion to the shift shock.
But perhaps more, make sure the pressure tables in your tune at part throttle are stock, Trust me even a 10 percent change can have dramatic effect here.
Did you assemble the 1-2 accumulator in correct order and stock ? springs then servo? I have seen a few people put in backwards thinking or seeing a diagram of a 700r4 set up.
In anycase unless you are sure its stock, I would look at the tune first then if all normal there (if you are not sure what normal is I am sure someone here or in the tuning section can share some stock tables for your vehicle.)
Also I do not know your engine build but have noted persons with super chargers and turbos can have issues with part throttle and 0 throttle up and down shifts particularly downshifts due to MAP signal spikes than can happen with these combos . Had a customer a while back with that issue, we looked at the data log and saw where on the downshift in particular the pressure would spike and noted that the same happened with the MAP signal. He did solve it but not being a tuner, I am not exactly sure how he did it. Many think only the MAF,TPS,RPM and SPEED affect shift times and pressures but actually a bit more is involved. I would certainly datalog if you can and look to see if any spikes under the conditions of the harsh or clunky shift.
If all looks normal in tune and other things I mentioned I would consider changing to a Corvette servo and drop the 2-3 feed to .100 or even .092 which is what I use with towing trucks and 4x4 with large wheels.
Forgot to mention, i use the 8TAD, 08 Tranny.
It already has only 1 short spring in the 1-2 acum and its already firm out of the box.
Yup, first spring and then piston (Replaced with a new aluminum one).
The clunk sound i get is when 3rd applies and when 3rd releases no matter what direction, upshift or downshift.
Its harsh when 2-3, 3-2, 3-4, 4-3. Its the servo banging for some reason.
Even the sonnax servo has to be 0.060" of travel right?
My shift pressures are stock
Next replace the servo release spring with a spring (The one between the case and servo ) with a spring from a 400 intermediate band servo it's a good bit stiffer and will increase accumulation for 3rd while lessening impact of the band applying too
If you do these things I think you will end up right where you want to be.
Normally with a higher stall 2800 or more your present set up would probably feel fine but with the stock converter not so much,
It's the bias ratio of apply vs release
It's how the timing works on the shift.
Fairly condescending to say "clearly don't understand fluid management"
Especially considering you posted a whole youtube video that outlines the fact that you have no idea how the sonnax 4th gear servo works.
There's many ways to skin a cat. I can make something live with the smallest 4cyl servo and I can make it live with the largest superior servo.
I can make either shift firm enough to knock your fillings loose, and I can make either shift soft enough that grandma wouldn't mind driving it to church.
We don't all have to do things the same. But we should all have a decent level of mutual respect on here.
