4L80 to 6L80 swap
They're usually just a flared end on the bracket. You can grind it then punch it out
Do the same with the 4l80e arm
And then swap the ball and weld the back side.
As for the linkage bracket yes you'll need to make a new one
Alternatively, to make this all easier, I believe all of these cables are 2 piece. You can get a lower half cable from an 07-13 truck/tahoe/suburban etc and swap that lower half out with your current cable.
That way the spacing and ball should all just be correct.
Then just adjust it into spec
New harness plugged into trans. Old harness zip tied out of the way for now.
New and old harness routing.
this is just a mess. I'll clean it up later.
The new TCM is tucked away down behind the fender. It's still in the ESD plastic bag.
I was thinking about attaching the ground wire and hot (12 vdc) here. The OBD-2 can be zip tied down there somewhere.
I also got the new Sonnax slip yoke swapped out and installed on the original (stock) driveshaft.
New Sonnax slip yoke.
Stock configuration
After straightening out the long part.
The bracket hole was at the wrong angle for the cable so....
I straightened out the bracket hole to about 90 degrees.
It was too thick for the cable seat all the way onto, and the hole was too small. I thinned-out the bracket hole area, and enlarged the hole.
All done, and painted.
I got some help this past weekend to cut and weld the crossmember. We basically cut a chunk out of the tube, turned it around, and welded it back in. The tube had to be cut about 1/2" for the mounting bolt to clear. Welding the cut out piece back inside was done for support. The flat plate had to be moved to the front side of the tube for the mounting bolt to line up. The flat plate was cut off about 3/8" from the mounting hole, and welded back on the opposite (forward) side of the tube. We used one side piece of the plate to support the plate from underneath. I still need to clean and paint it before installing it. I'm gonna try to do that this weekend.
BMR 4L80 crossmember before mods
top view after mods
bottom view after mods
1) I got the cross-member fully bolted in. The driveshaft is fully installed. The torque arm is fully installed.
2) I had to make some more mods to the shifter cable bracket. With the cross-member fully bolted on, the bracket was too high. It caused the shift cable to hit the body of the car. So, I cut off the "C" part of the bracket and welded it lower. I was also able to get the original 4L60 shift lever back from the guy I sold the 4L80 to. With the bracket in the lower position, the original shift lever lined up quite nicely. I haven't installed the shifter bracket yet. I just painted it, so I'll try to install it tomorrow.
3) cut and spliced the throttle position sensor wire into the new TCM wire. I was finally able to get the nut loose on the relay box. I used that bolt for the battery-direct power wire on the TCM. I still have to figure out where I'm going to get a "switched" 12v power source for the TCM. I also have to "tap" into the engine speed somehow.
I'm having trouble with my iphone not sharing pics right now. I'll try to get that sorted out and post them.
1) Cross-member, torque arm, and drive shaft:
2) Shifter cable bracket:
cut, and marked for welding
welded
primed, waiting for paint
3) Wiring:
Power and ground wires connected
Throttle Position Sensor wired
It's in further than it looks. This is not a factory slip yoke. It was meant for a 4x4 6L80, so it's much longer. I measured the slip yoke before and after install. It has about 3" of spline engagement with the trans. The 4L80 slip yoke barely had 3" of splines.
shift cable bracket painted
shift cable bracket installed
shift cable adjusted and installed
What shifter will you use with this?
What type fitting is in the trans that you have to use the ICT adapter plate?
Do you know the weight difference between 4L60, 80 and this?
Is that TCM2650 really a grand!? lol
2) I don't know what it's called, but it looks like the 6L80 uses a "push-in" type hard line. This pic below is the best I have that shows the opening. It looks like it has a metal-rubber seal around the opening. You can't stock use gen-4 lines with this transmission. You might be able to fabricate your own, if you're that good, but ICT Billet makes it easy.
junkyard 6L80
3) I have no idea what the weight difference is, but I'm sure it's huge. The 4L80 makes the 4L60 look small. The 6L80 looks like a 4L80 with a pot-belly. Going from a 4L60 to a 6L80 would be a huge weight difference, but sometimes necessary.
4) Yes. $975 plus shipping. I'm not an electronic engineer, so I have to pay the price.
This is the most expensive mod I have done to my car so far. I wish I could have done this instead of the 4L80 though. If you still have a 4L60, this is the swap to do. I wouldn't bother with the 4L80 if you have the budget for a 6L80. The 6L80 gives you the strength you need, and the gear ratios you really want.
[/QUOTEI understand you're using the stock cable, but what about the shifter itself? I don't understand how the 6L works...are you able to "shift" a 6 speed with a 4 speed shifter?
Do you know if paddle shifters are an option for this trans?
Understand original line won't reach around to drivers side, but does it use the same hard-line push-in type connection the 4L uses?
yeah was just curious if you had any idea the difference. I've been looking at this swap for a while and trying to decide the expense, weight difference, etc would be a good idea for me or not. I Autocross my car. Rebuilt 4L60E that I can manually shift when & were I want. I normally only use 1 & 2 gear. 98% of people use a manual trans, but that swap is approaching $5K by the time you buy a good trans, shifter, clutch PP & flywheel, pedal swap etc..
[/QUOTE
Yes, paddle shifters are an option. There is a wire in the TCM harness for that. I’m not using it though.
The hard lines are a different size. The adapter is really the only option.
