Yank guys
I'm just surprised/ disappointed its still dropping the same as the SS. Makes me wonder if he even did anything different to it. It sure acts just like the SS. Any thoughts from you guys?
How would the SS compare to the PT? Is it at the hit? More stall with less torque needed or vice versa?
The reason I ask came about in a discussion with Circle D. At first I was just another street hero wanting a stall converter. When I stressed the drag racing aspect (and leaving street off the table) the spec changed to their Pro Series. I think though that had to do with diameter/stall requested. Their HP line is an 11" vs the 9.75" spec'd for me.
A quote from Brian at Circle D.
This converter is our smallest/most aggressive 9.75" diameter. We have found it compliments the power delivery of the naturally aspirated engines quite nicely. Since you're looking to maximize your track performance, I don't see any problem with a stall speed around 4000 rpm.
Would it be fair to say that the differences might similar to the ST vs the PT?
I also spoke with Dave at Yank and he recommended their SS4000. That too was a conversation that didn't emphasis the racing part.
I'm exactly in that spot where you are/were. SS4000 as suggested by Meyers or a PT4000 if there's a benefit and no downside.
This is the move I was contemplating again as that TCI converter is still in play. Or was anyway as it'll need to be cut open and gone through and it's not worth it.
This SS vs PT conversation has me re-thinking the plan. Still more converter companies yet to be heard from (I've got a half dozen leads out there).
The difference in shift RPM's notwithstanding do you drive on the street as well? Where thee discernable differences between the the two types?
