4L80 shift question
Old Feb 22, 2024 | 06:30 AM
dw456post's Avatar
Default 4L80 shift question
When in 1st gear, my 4L80 shifts to second gear. I don't want it to do that. I want it to hold the gear it is in. My last one was like that.
Any tips on what to do. I am using the same tune for the "new" 4L as the old trans. I would rather do it internally than change the tune.
Thanks
Old Feb 22, 2024 | 09:01 AM
jakeshoe's Avatar
That's absolutely controlled by the tune unless you use a full manual VB.
Old Feb 22, 2024 | 10:46 AM
MaroonMonsterLS1's Avatar
Agreed.
That is 100% tune-controlled unless there has been a major vb change
Old Feb 22, 2024 | 11:35 AM
FranksCustomTrans's Avatar
LS1Tech Sponsor
Its a super easy fix in the tune if you have HP tuners or know someone who does. or if older 93 to 96 Tunercat otherwise Transgo kit
__________________
Old Feb 22, 2024 | 02:04 PM
dw456post's Avatar
I have HPTuners. I have seen the write up on Gen 3 computers using the Urban shift. I have a Gen 4 E38 and 2006 4L80. The Tune does not have the urban shift button. Is that the same as D2 ? I have Normal, D1, D2---Pattern A, D2---Pattern B, D2. Pattern B has the D2 populated with all 318 and not let it shift. Pattern A, D2 has all 0's except the last two cells. Is this where I need to shut off the shifting?
Thanks !!
Old Feb 23, 2024 | 08:19 AM
Well if you're trying to get it to hold in D1...then you should look at the D1 table
Old Feb 25, 2024 | 01:37 PM
dw456post's Avatar
My D1 table has 318 in it already. Last 4L80 that I had an it held 1st.
Old Feb 26, 2024 | 12:00 PM
LS1Tech Sponsor
Thanks !!
Sadly I am not that familar with HP in tuner cat its simply in a table that has M1 **** point and I just change it 100 mph and if you want to be able to downshift manually at any speed another place that shows max downshift to m1 speed .
Beyond that you will need someone with HP to answer that question.
__________________
Old Feb 26, 2024 | 03:33 PM
Take a datalog and doublecheck everything
Log solenoids, tps, speed, and recognized shift position
Old Feb 26, 2024 | 06:25 PM
miketx's Avatar
Thanks
SImple, put the gear selector in the "1" position.
Old Feb 27, 2024 | 02:56 PM
dw456post's Avatar
LOL---not on a 4L80
I put 318 in the D2 box and now it doesn't shift to second gear.
