4l60e missing 3rd and od
Old Apr 21, 2024 | 08:49 PM
Chonea's Avatar
Default 4l60e missing 3rd and od
Hello everyone.
i searched round and couldnt find this problem. I had my 4l60e rebuilt about 10 years ago, since then i have put maybe 1000 miles on it as i havent needed it and its been my slow project. I finally got it built to a place where i want to start driving it. But when i drive, it shifts from 1-2 fine then 2-3 is like throwing it in neutral, if i get 2nd up high enough i can feather the gas pedal and get it into 4th but it wont go into overdrive. Any ideas? I have replaced basically every sensor tps etc. the rebuild was supposed to have included all new electronics, heavy duty clutch packs upgraded servo etc. any ideas?
Old Apr 22, 2024 | 07:02 AM
MaroonMonsterLS1's Avatar
4th is overdrive...so if you're getting it into 4th you're getting overdrive. Sounds like you have mechanical issues
Old Apr 22, 2024 | 07:40 AM
2BFAST's Avatar
Are we 100% sure we're full on fluid?
Old Apr 22, 2024 | 08:02 AM
Chonea's Avatar
Default Gears
I should have said the torque converter is not locking up, and yes fluid is good, transmission is at 163 degrees and in the cross hatch.
Old Apr 22, 2024 | 09:15 AM
You can connect a scan tool and determine what is being commanded.
Pair that with a line pressure test
And you'll have confirmation on the status of this unit
Initial description sounds like mechanical issues
Old Apr 22, 2024 | 09:35 AM
Chonea's Avatar
I have a scan too, what exactly should I look for being commanded?
Old Apr 22, 2024 | 03:19 PM
Which gear is being commanded
Whether or not lockup is being commanded
PCS amperage commanded vs actual
Pair all that with a pressure gauge monitoring the line pressure of the trans and you can make a good determination of what might be wrong
Old Apr 22, 2024 | 03:47 PM
Chonea's Avatar
I did watch as the scan tool showed each gear that was being commanded. Didnt see that it commanded a lockup. Ill have to check pressure and get back.
Old Apr 25, 2024 | 08:20 PM
Chonea's Avatar
It finally pop a vss code today. I havent had time to do much with it but hopefully thats all it is.
