4L60e troubles
Old May 25, 2024 | 05:19 PM
Jaxson.Stene's Avatar
Default 4L60e troubles
So I just am finishing the swap on my 1984 c1500 put a gen 3 5.3 in it with a 4L60e trans. I went to drive it today and it doesn’t want to shift. Then when I shift it manually “with the column shifter” it shifts into 3 then I give it gas and there nothing. If I stab the throttle I get nothing like a 2ed neutral. Could this be a solenoid gone bad or a clutch pack? Please help me 🙏
Old May 25, 2024 | 06:29 PM
RB04Av's Avatar
Sounds kinda like something wrong with the 3-4 clutch pack or the various control circuits in the valve body that actuate it.
Prob not a solenoid, butt ... can't totally rule it out.
I've also come across situations where a sprag installed backwards can cause weird stuff like this. Has this transmission EVER worked since it was last built, or is this a fresh rebuild?
Old May 25, 2024 | 06:35 PM
No it has never been opened from my knowledge. It has 179km on it. Would it be worth rebuilding or just buying a 4L80e just be a better investment?
Old May 25, 2024 | 06:55 PM
RB04Av's Avatar
Did it ever work, that you've seen?
Hard to say.
What's in front of it? Behind it? What is the truck used for?
Old May 25, 2024 | 10:19 PM
bbond105's Avatar
Does your speedometer work? Do you have a scanner that will show if the shifts are being commanded?
Old May 25, 2024 | 11:15 PM
No it has never worked to what I’ve seen just drove it for the first time and doesn’t shift.
Just a gen 3 5.3 with a truck Norris cam. My Ecm has been tuned just a bench tune at the moment though.
It is used as my daily driver, never tow anything with it just hauls my dirtbike. Haven’t hauled anything with the new motor and trans thought.
Old May 25, 2024 | 11:16 PM
Yes I have an edge Cts 3 in it. I haven’t look to see if it has commanded the shifts tho
Old May 26, 2024 | 10:19 AM
FranksCustomTrans's Avatar
LS1Tech Sponsor
First thing is to see if shifts are being commanded, Also to check 3-4 clutch integrity , unplug harness and manually shift you should be able to start in 2nd and manually shift to 3rd
__________________
Old May 26, 2024 | 03:31 PM
bbond105's Avatar
No speed signal, no shift. Check that at least you are getting a speed signal to the PCM.
Old May 27, 2024 | 11:19 PM
I am getting speed signal still no shift
