4L60E, can it be unpluged to perfrom a wire test?
Old Jun 10, 2024 | 02:13 PM
OddJack's Avatar
Default 4L60E, can it be unpluged to perfrom a wire test?
I mean without moving the transmission?
Talking about the case connector on top.
The purpose is to check the voltage coming from PCM to the harness.
Old Jun 10, 2024 | 02:57 PM
FranksCustomTrans's Avatar
LS1Tech Sponsor
If you are just wanting to check voltage to Pin E sure, Though you would get a better loaded test with harness plugged in and tapped into pin e wire and PCM does self test with solenoids loading circuit,
__________________
Old Jun 10, 2024 | 03:08 PM
OddJack's Avatar
Thanks Franks,
This is what I am trying to do:
Old Jun 10, 2024 | 04:53 PM
bbond105's Avatar
Yes, it can be unplugged with trans still in the vehicle.
Old Jun 11, 2024 | 07:26 AM
2BFAST's Avatar
Just make sure when you go to plug it back in you dont push the trans harness connector in the transmission. You will have a mess on your hands and you will be pulling the pan to reinstall it.
Old Jun 11, 2024 | 09:07 AM
bbond105's Avatar
Sonnax makes a bracket that stops that from happening. I install it on all of my personal transmissions.
Old Jun 11, 2024 | 10:06 AM
LS1Tech Sponsor
Yes i make one with the dipstick stop since the pans I use have that made into them.
__________________
Old Jun 11, 2024 | 12:13 PM
2BFAST's Avatar
Yup, I do the same. They make one for the 4L80E too.
