Transmission issues
Old Oct 3, 2024 | 12:57 PM
Jim Abron's Avatar
Default Transmission issues
At the end 1st gear & 2nd gear it stall shifting to the next gear. 3rd gear on out it’s no issue. Drives smooth.
Old Oct 3, 2024 | 04:50 PM
the_merv's Avatar
Veteran: Air Force
The amount of information you just posted for us to help you is absolutely astounding. I am completely awestruck by how detailed you are.
Seriously dude, come the **** on....
Vehicle?
Engine?
Transmission?
Known issues already?
Put a scanner on it to see codes?
Lets actually elaborate on this here...
Old Oct 4, 2024 | 12:14 PM
FranksCustomTrans's Avatar
LS1Tech Sponsor
More info would be helpful, is this at WOT when and greater explanation of stalls ?
__________________
Old Oct 4, 2024 | 07:45 PM
Jim Abron's Avatar
2002 Camaro ss 35th anniversary all original everything.
Can anyone help me out?
Old Oct 4, 2024 | 07:53 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Nobody can help you without more detailed information. The only thing we can advise, based on what is known so far, is to take it to a shop with professional automotive technicians for a proper diagnosis and repair.
Old Oct 4, 2024 | 10:05 PM
the_merv's Avatar
Veteran: Air Force
I gather LS1 with a 4L60E if its all "original".
Atleast you all see my frustration with this. People want help and give you nothing to be able to help them with.
Old Oct 5, 2024 | 03:41 AM
bob4360's Avatar
Here is my guess at the above information.
He says it shifts okay 1 to 2, then there is a delay to 3, and from then on to 4 etc all works okay. It would be nice to know if it changes with pushing harder on the gas or not. Has the fluid been checked and or changed?
People don't understand we can see or hear problems on a computer and need very detailed information to try to help.
Old Oct 5, 2024 | 10:37 AM
LS1Tech Sponsor
Yes and it happens even more on the FB forums and sadly many are "buiders"
__________________
Old Oct 5, 2024 | 03:49 PM
bbond105's Avatar
Please give a better description of your problems. It is hard enough to help over the computer with a good description of the problem, but your description is very confusing.
What do you mean by “stall shifting to the next gear”? Please elaborate on stall shifting. When does it stall shift, part throttle, full throttle, trans hot or cold. We need info along these lines to be able to help you.
Old Oct 6, 2024 | 07:41 PM
the_merv's Avatar
Veteran: Air Force
I've been in here more lately because this is still one of the few things I'm in that hasn't turned to ****. I've dropped out of many FB groups for that reason, as wll as other car forums.
Old Oct 6, 2024 | 08:56 PM
LS1Tech Sponsor
Yes I get into some of the facebook groups and want to pull my hair out just reading and I DO NOT HAVE THAT MUCH LEFT LOL.
__________________
