4l60e rebuild questions
Old Dec 6, 2024 | 02:53 PM
2BFAST's Avatar
Is this a new rev drum? Or did you reuse and install new bushings? Or is this a machined drum with new bushings?
Old Dec 6, 2024 | 03:08 PM
tonyorlo's Avatar
I reused the original and installed new bushings. Is that a bad idea?
Old Dec 6, 2024 | 04:42 PM
bbond105's Avatar
It is a very good idea to replace the bushings, but most likely you have a burr on the ID of one of the bushings or the bushings are not straight in the bore. If driving the bushings in with a hammer a lot of time this will burr up the edge of the bushing where the drive hits the bushing.
File Type: pdf
Old Dec 6, 2024 | 08:09 PM
tonyorlo's Avatar
I’m going to replace the drum, something is obviously wrong with it. It’s most likely the guy who installed the bushings fault (me!). Is there a preferred drum to go with?
Old Dec 7, 2024 | 10:14 AM
FranksCustomTrans's Avatar
LS1Tech Sponsor
Amazon Amazon
This is a new GM drum, Yes they are made in Taiwan, You can also get these in off brand like 20 dollars cheaper but still made in taiwan (honestly had both compared I think same one as cant find a difference) optionally WIT TRANSMISSION parts sells remans also fine.
As mentioned I have had little luck with installing bushings with bushing driver and hammer, I you do it must be done gently and slowly . To me a press is a must.
As mentios
__________________
Old Dec 7, 2024 | 06:32 PM
bbond105's Avatar
A press is definitely the way to go. It can be done with a hammer, but you may have to massage the bushing a little to get it to fit right sometimes.
Old Dec 9, 2024 | 07:28 AM
2BFAST's Avatar
I would say you found your problem
Old Dec 9, 2024 | 10:28 AM
bbond105's Avatar
There is nothing wrong with installing new bushing and reusing the original reverse input drum if it is in good shape.
Old Dec 9, 2024 | 10:57 AM
2BFAST's Avatar
I would say he has a bushing or bushings caddywompis in the drum
Old Dec 10, 2024 | 08:03 AM
tonyorlo's Avatar
I’d say you’re right. I’m just going to buy a new drum. A friend is giving me an arbor press, which will be perfect for this type of work.
Old Dec 10, 2024 | 09:53 AM
2BFAST's Avatar
Yes an arbor press is ideal for this, but a hydraulic press will yield the same results
