Th400 no front endplay
The extreme hub adds .025 to it's cross section, the HD hub says it is thicker but does not give a specification.
Make sure the torrington bearings are faced correctly. I had a flange turned upside down once and didn't have end play.
Make sure the Sun gear is not upside down.
Put the factory hub back and check end play.
No need for clutches while checking this over again.
