Transmission band tabs
No reverse with a 60e SUNSHELL STRIPPED. LOW PISTON BROKEN OR FRICTIONS BURNED, BROKEN APPLY PISTON OR BURNED FRICTIONS REVERSE INPUT DRUM . This all assuming a running unt that just lost reverse. If it is a new build with no reverse other things are possible. As BBOND105 said LOOK DEEPER . Though with a damaged band and no reverse I would say a full rebuild is in order anyway.
Therefore, it think it best to close this one. PM me if you think it should stay open.
