Going in OD under power
Old Feb 12, 2025 | 07:57 AM
DRIVER456's Avatar
Default Going in OD under power
Is going into OD in a built 4L60E under power in dragracing a no no?Will it damage any thing?
Old Feb 12, 2025 | 08:04 AM
2BFAST's Avatar
Not sure you would really need to?
Old Feb 12, 2025 | 09:31 AM
DRIVER456's Avatar
Doesn't answer my question
Old Feb 12, 2025 | 10:00 AM
Finkledbody's Avatar
what’s built in the transmission? Or what company built it and what stage?
how much power you making?
Quality of the question’s determines the quality of the response. Hence: limited question, limited response. Just for reference.
Old Feb 12, 2025 | 10:11 AM
DRIVER456's Avatar
I built it,It has pretty much every HD part that sonnax makes,I'm around 740HP.It holds up to 1.4x 60ft and 10.00 in the 1/4mi. every weekend.If you need to know about a single part let me know.
Old Feb 12, 2025 | 10:12 AM
bbond105's Avatar
It can be done, but the transmission will need to be built to handle it.
Old Feb 12, 2025 | 04:27 PM
FranksCustomTrans's Avatar
LS1Tech Sponsor
Wide band, new rev drum, sonnax od servo, pin leak addressed, 4th accum blocked . large servo feed hole .093 or larger. 220 to 230 max line at WOT and yes, But will still be hard on the band, its a big jump right at 30 percent, And more with wind resistance of the car will be about like having a car that weighs 2x as much . But yes can be done , I would not suggest it daily and a solid 3-4 clutch set up also a must as those frictions while already applied have to hold all of that too, I would say an 8 friction and no leaks in the 3-4 hyd.
But even with all of that I would not suggest it regularly unless you are reared really low like 4.11 4.56
__________________
Old Feb 12, 2025 | 05:52 PM
DRIVER456's Avatar
Thank you!!
