Th400 converter turbine locked up
Old Apr 5, 2025 | 07:21 PM
mirage2991's Avatar
Default Th400 converter turbine locked up
New fti sst converter decided to lock its turbine solid for reasons beyond my comprehension.
wasnt doing anything drastic. Drove 3 miles, then wanted to test the stall so put it in 3rd (manual valve body), break stalled it, got some boost built up like 7 psi, let the brakes go and rolled in the throttle.... with street tires that made for a nice smoke show but within second of letting the brakes go, it was game over. Came to a stop, motor stalled out like when you forget to push the clutch on a manual.
converter is out, can confirm i have no turbine rotation in any directions.
Stator moves as it should, smooth (mechanical diode).
sparkles in the fluid out of the converter so looking like a full trans fluid change, new screen and flush out the cooler is in order... yay me... trans has 200 miles and brand new (stage 4 fti).
anyway.... anyone knows why it would do that?
Old Apr 5, 2025 | 09:15 PM
Tranzman's Avatar
Sounds to me like someone made a mistake... Not you!
Old Apr 5, 2025 | 09:59 PM
mirage2991's Avatar
yeah, new one for me... would love to know what went wrong. I'll be calling them monday am for my next step (which I assume will be shipping it back to them).
Old Apr 8, 2025 | 10:24 AM
FTICONVERTERS's Avatar
LS1Tech Sponsor
Mirage, if you haven't called us already. give me a call. I can get you a return and get the converter here for inspection ASAP so we can get it fixed for you.
-Dalton
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old Apr 8, 2025 | 10:57 AM
mirage2991's Avatar
-Dalton
I called monday am and sent it out ups on my dime that day. I can't recall whom i talked to. As an aerospace engineer i am really interested to know what went. My educated guess would be something like a washer or Torrington bearing not properly hardened from the oem or maybe the tolerances went out after welding.
S happen but that trans is brand new to (200 miles)... one of your stage 4... hope it's ok! (I think it is but will pull pan later this week)
Old Apr 8, 2025 | 11:26 AM
LS1Tech Sponsor
I called Monday am and sent it out ups on my dime that day. I can't recall whom i talked to. As an aerospace engineer i am really interested to know what went. My educated guess would be something like a washer or Torrington bearing not properly hardened from the oem or maybe the tolerances went out after welding.
Can I offer some extra FTI merch like a couple shirts or a hoodie in exchange for the freight you covered? We'll know if the transmission needs to be looked at after we cut the converter open. Based on my suspicions I think the transmission will be ok. but if it does need attention I will make sure we take care of that for you too since it is one of our transmissions.
Can you PM me your name and address please? that way I can get right on the converter as soon as it comes in.
-Dalton
__________________
1-866-726-8358
FTIPerformance.com
Old Apr 8, 2025 | 12:33 PM
mirage2991's Avatar
-Dalton
Thanks Dalton, I appreciate the support! I sent you a pm.
Old Apr 8, 2025 | 04:38 PM
bbond105's Avatar
-Dalton
Can't ask for much more than that, Dalton and FTI are one the ball. That's great customer service.
Old Apr 8, 2025 | 07:26 PM
mirage2991's Avatar
I agree!
Old Apr 10, 2025 | 04:30 PM
mirage2991's Avatar
Converter is on its way back to me thanks to Dalton who took care of it right away. Could not ask for a quicker turn sound. Literally got it wed afternoon and done today (Thursday).
looking forward to cruising again!!!
Old Apr 10, 2025 | 04:46 PM
bbond105's Avatar
Wow!!! That was fast.
Old Apr 10, 2025 | 05:00 PM
LS1Tech Sponsor
Happy to be of service!
-Dalton
__________________
1-866-726-8358
FTIPerformance.com
Old Apr 11, 2025 | 01:12 AM
91 Z28's Avatar
Hell yea that's wild how fast it got turned around!! FTI for the win
