rebuilt 4l60e issues
Old Jun 13, 2025 | 11:25 AM
FranksCustomTrans's Avatar
LS1Tech Sponsor
Originally Posted by 2BFAST
Mine is setup this way
I do not see any issues with it overall, the release capsule in case should provide plenty of release. Just not sure what advanage it offers. I have seen it done in the 700R4 . Just never saw a point to it is all. My perspective is always "whatever works for you" You will not see me put down anyone's mods unless they fall into the ridiculous category and even then I will ask the logic of the mod first before making judgement. Hey I learn something every day, When someone comes in as the end all be all , know it all . Those people I have little use for because they are no longer learning nor care too.
One of the reasons I like VORTECH so much with all his expertise on he literal design he was personally involved with . He still was alway interested in new and better ways. Like My overun mod he liked because of its simplicity and ease to undo if someone disliked the feel.
__________________
Old Jun 13, 2025 | 10:22 PM
67SSRS's Avatar
Dug a little more today, found the 3-2 valve was stuck.and it also had no spring on it
Old Jun 14, 2025 | 10:52 AM
LS1Tech Sponsor
Could cause 2-3 and 3-2 issues .
__________________
Old Jun 15, 2025 | 12:55 AM
Tranzman's Avatar
The 3-2 downshift valve can be blocked in board and it will not affect anything. Actually it's part of TransGo's 4L60E-HD2 kit. The tight wound purple spring. Page 2 step 1 of the attached instructions. @maroonmonsterls1 blocks both the 3-2 downshift valve and 3-2 sequence valve inboard on all 4L60E builds and I block 90% of them myself.
Not sure if it was to be stuck outboard if it would actually do anything. I would have to look at oil diagrams.
One of those 2 valves was eliminated from 2009 and up units, can't remember which right now.
File Type: pdf
Old Jun 16, 2025 | 07:10 AM
2BFAST's Avatar
Every unit I have done (which isnt much compared to most on here) I have blocked both 3-2 valves inboard
Old Jun 16, 2025 | 10:13 PM
brandon6.0's Avatar
OP have u made sure the main connector is installed correctly. I know on some LS swap harness u can plug it in backwards and will do funny stuff like u mentioned. I'm not sure about the Holley harness being like this. Always face the arrow outward.
Old Jun 17, 2025 | 06:57 AM
67SSRS's Avatar
yea thats what o was hoping for and one of the first things I checked with no luck
