Donkey-Kick TCC
CircleD triple disc on 4L80.
Is it "safe" to lower the minimum pulse width on the bottom two-thirds of the PWM vs LINE pressure table?
How low can I go ?
I have the left 4 columns at 29 (%) now. Can I reduce these values ?
How about the hgh temperature row: Should I leave that alone ?
MAX is all 100% ( stock was 99% ) is there any practical difference between 99 and 100 ?
How low can I go ?
https://www.sonnax.com/tech_resource...ction-material
you know what I did on mine…. I set it to lockup in third gear at a low mph and raised over drive shift mph. I can post my tables if interested. It gets better fuel mileage this way. If you give it more throttle…as you give it more, it locks up later and later. Also at cruise, it comes out of lockup fairly easy with more throttle input. I put alot of time into smoothing it all out and making it drive really nice
........... Yes .... I would very much enjoy a view of your trans tune numbers.
I get so lost in the combination of upshift speeds vs TCC lock speeds, TPS vs MPH downshift speeds, UNLock speeds... my head spins, and I go drive something else for a few weeks. Then start over at ground zero, not knowing what I last dicked with... I put the turbo on back in July2024, dialed in the VE, spark dead nuts on, meth ramp in rate, all running VERY good. The transmission shift timing, especially around part throttle cruise, low speed limit, following slow traffic, hills under 50 miles per hour- all this local driving is HARD to tune for.
ANY comparative reference material is much appreciated. Thanks in advance.
here you go (stock cable drive throttle body)
Its going to be firm
Nature of the beast.
Install an aftermarket exhaust and it's expected to be louder. A triple Disc should be expected to be alot more firm.
That said you do have options
Trying to adjust the pwm table to make it slip and soften it up is going to be bad for it in the long term. Id recommend against that
I'd do what KFX did. Lock it up sooner and at lower load so you don't go from a large difference between engine rpm and input rpm. That's ultimately what feels so agressive is the engine is at 3500 and the input shaft is at 2000 and you lock it up and those 2 numbers have to match.
KFX gave good advice and his tables look nice. Reasonable speeds and loads for everything.
Adjust as needed to fit your gear/tire combo but he's provided a great starting point.
okay i have a new tcc solenoid here and my old wire harness and its got little plastic block that prevent it from being plugged in backwards. I was thinking the tcc solenoid couldn't be bad since lockup disengages when i unplug the harness and thought the pcm was giving lockup signal wrongly. but maybe the solenoid is bad and just can only impoperly function when given it's power from the harness, the 12 constant power not the pwm grounded in the pcm wire.
so i guess if the pcm is bad i will see 0v on the pwm wire with the harness plugged in and idling in park, and if the pcm is good it should be a 12v potential and is likely a bad solenoid.
O and i will get an ohm reading on the tcc solenoid, supposed to be 10-20 ohms, or anything that's not 0 or infinite.
