6L80E slip yoke - which one?
Main question:
I need to replace the current driveshaft to a slip yoke system. Does anyone have a link to the correct slip yoke? Is it as simple as unbolting the removing the current 3 bolt mount, adding the slip yoke, and have a drive shaft company build a new drive shaft?
I have also seen the method of an adapter that mounts to the 3-bolt flange, and then an additional adapter slip yoke device mounts to the drive shaft. With this I'm worried about space and adding addition adapters to the drive line.
Any help is appreciated.
Main question:
https://ls1tech.com/forums/conversio...-question.html
Main question:
