8HP Transmission
Old Apr 7, 2026 | 09:36 AM
BruiserConversions's Avatar
Default Feedback Wanted: OEM-Controlled 8HP Swap Setup
We’ve been working on an 8HP swap solution that keeps everything under OEM ECU control instead of using a standalone transmission controller.
The idea is simple — make the swap behave like it came from the factory:
  • No external TCM
  • No CAN translation modules
  • No valve body modifications
  • Full OEM-style drivability and tuning control
We’ve already proven the concept in multiple builds, but wanted to get feedback from the community:
👉 If this was available as a package:
  • What platforms would you want it for?
  • What concerns would you have?
  • What would make or break the decision for you?
Trying to build something that actually solves problems instead of adding complexity.
Old Apr 9, 2026 | 10:07 PM
Paul Bell's Avatar
That's MISTER MODERATOR
  • No external TCM
This uses a Dodge ECM for the transmission AND engine, right?
Paul Bell's Avatar
https://8hp.club/
Old Apr 13, 2026 | 10:15 AM
correct everything running of the GPEC2A
