1-2 shift problem
Old Aug 7, 2004 | 05:32 PM
vince87t's Avatar
Default 1-2 shift problem
I just had a Transgo shift kit installed and now my car (2001 Z28 Conv) feels like it dies when it shifts to second gear. The car also has a Vig 3000 converter. All was fine before the shift kit. If I let up and get back in it all is OK.
HELP!!!
Thanks,
Vince
Old Aug 7, 2004 | 07:22 PM
Automatics's Avatar
Restricted User
If you have "torque management", this will happen. You have to disable it. Once you disable this, you can increase the 2nd, 3rd, & 4th gear feed holes in the valve body plate. This can extend the life of the transmission, whilr firming up the WOT shifts.
Old Aug 7, 2004 | 09:41 PM
vince87t's Avatar
Thanks. I am new to the LS1 cars. How should I disable torque management?
I thought that the torque manangement was only on the shift. What is happening on mine is that the car will stay at about 4200 RPM after the 1-2 shift until I let off the throttle. It will only rev in second if I let off and get back on it. This only seems to happen at 3/4 to full throttle. Still torque management? Are you near Pgh PA? I appreciate your help.
Thanks,
Vince
Old Aug 11, 2004 | 09:41 PM
vince87t's Avatar
Anyone else have this issue?
Old Aug 11, 2004 | 09:45 PM
Cerebrex's Avatar
adjust TM with a programmer
Old Aug 19, 2004 | 08:05 PM
vince87t's Avatar
I am going to a shop to "program" the car tomorrow. What should I look for?
Thanks all,
Vince
Old Aug 19, 2004 | 09:41 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Torque management can be a killer, but also I had to raise the rev limiter on my car when I had the TC installed. It was hitting the limiter on the 1-2 shift at WOT every time. I only have a HPPC 3 to adjust mine, but it at least allowed me to raise the limiter to stop the engine from virtually shutting down on the shift.
Old Sep 7, 2004 | 10:44 PM
vince87t's Avatar
TTT.
The guy that was going to tune my car keeps putting me off. I am near PGH Pa if anyone out there can help and is close by.
Thanks,
Vince
Old Sep 13, 2004 | 10:16 PM
vince87t's Avatar
Anyone near PGH PA that can help on this? The guy that was supposed to help has cancelled my appt twice. Call me at 412-559-8282 if you can help.
Thanks,
Vince
Old Sep 27, 2004 | 10:48 PM
vince87t's Avatar
TTT
Anyone?
thanks
Old Oct 6, 2004 | 02:43 PM
vince87t's Avatar
ProBuilt, How can disable the Torque management? I am in Pittsburgh PA. If you are close I would be hapy to bring the car to you. What would you charge to check it out and possibly fix it?
Thanks,
Vince
412-559-8282
Old Oct 6, 2004 | 04:22 PM
jimmyblue's Avatar
Moderator
I got into something like this while I was trying to
make a "soft" torque management. The deal seemed
to be, if enough timing got pulled, the thing would
go to some kind of "purgatory" - drop enough RPM
back that it didn't quite want to shift, or something.
Best bet is probably the PCM sections and your local
section, call out for someone w/ HPTuners and your
model/year. That's the only tool that isn't all locked
up from helping your buddy (just by year and vehicle
type).
Old Oct 6, 2004 | 06:30 PM
Automatics's Avatar
Restricted User
Talk to Ed Wright on this.
Old Oct 9, 2004 | 08:18 PM
vince87t's Avatar
How can I contact Ed Wright?
Thanks,
Vince
Old Oct 21, 2004 | 03:49 PM
vince87t's Avatar
TTT
I am looking for someone out there that is within 2 hours of Pgh PA that can do a professional tune to Eliminate my problem (seems to be Torque Management).
Thanks,
Vince
412-559-8282
