cooler install how to?
Old Aug 22, 2004 | 03:30 PM
john shea's Avatar
Default cooler install how to?
I've been reading these cooler install guides online and they have really
confused me. I would think you block off the old fittings and install to new
cooler or T it in somehow.Can someone explain this to me because I just can't follow what the pictures show?Thanks for any help.
John
Old Aug 23, 2004 | 03:21 AM
tici's Avatar
Usually you install the new cooler after the stock, with both barb fittings on the top (this will avoid air to be trapped in the cooler).
I don't think bypassing the stock cooler is a good idea: the trans need a certain operating temperature to work properly.
You also should change (lower) the fan settings: the normal air flow won't be enough to cool the oil. 175F is a good temperature.
Be careful with the lines: there is a certain pressure in the system. I firs used the hose that was in the kit: you can see it "pumping" when you accelerate in P. I went with stiffer hoses (hi temperatire, hi pressure, oil resistant).
Old Aug 23, 2004 | 03:36 PM
thebernsZ28's Avatar
I'm in your shoes, I'm getting help from my friends who have done it before. I don't want to screw it up. Sorry no tech info.
Old Aug 23, 2004 | 03:59 PM
boomcase's Avatar
I think the top line is the return line, so you leave your botton line connected to the radiator and the run a barb fitting from the top hose to the new cooler and then the other end of your aftermarket cooler to the factory line, just push the fitting down the line and slide the hose over it a clamp it , this way your stock cooler and after market cooler work as one....
Old Aug 23, 2004 | 04:52 PM
tici's Avatar
Look here for some pics:
http://www.bfranker.badz28.com/94z/trannycooler.htm
In this page the inlet is the lower connection.
http://www.fbody.com/tech/details.cgi?id=31
In this page they install a B&M cooler with the connections downware: it's wrong! They have to look upwards.
If you need another hose (you probably will) just ask for high pressure, high temperature oil resistant hose... to spray the engine with ATF is not nice.
