Driveline vibration?
Old Aug 22, 2004 | 06:25 PM
greenalien00's Avatar
Default Driveline vibration?
Last week I put in a TCI ssf and now i have a vibration of some sort.
ANy suggestions?
Thanks
Old Aug 22, 2004 | 09:58 PM
Cheatin' Chad's Avatar
Is it in all gears?
Old Aug 23, 2004 | 02:04 PM
i think so but not sure nest time i take it for a spin later ill make sure to pay attention. im pretty sure it is cause its not as bad a slower speeds but when i accelerate it gets worse.
Old Aug 23, 2004 | 04:26 PM
40mph in 3rd I get the vibration. In 2nd or 4th there is none.
Old Aug 23, 2004 | 06:22 PM
ya i drove it today and i think it started around 40mph in 3rd or 4th so got any ideas?
Old Aug 23, 2004 | 06:53 PM
If it's only in one gear it's likely something to do w/the trans or the converter(possibly).
You and I aren't the only ones that have posted about vibrations after installing a TCI converter.Could this be the problem? It could be (along with a few other things) but I have not done enough w/my vibration problem to say it is or is not the cause.
Maybe someone else will chime in with their results.
In the meantime:Have you checked your pinion angle? Are you using a poly transmount?
Old Aug 23, 2004 | 07:32 PM
Evil 99's Avatar
is the T/C clutch coming on when the vibration is present? if it is does it go away above 65-70 mph?
Old Aug 24, 2004 | 01:08 PM
Raptor99's Avatar
I'm getting a weird vibration from mine too, but only after the verter locks up.
I don't know if yours is a lockup problem, but try to re-create the problem, then tap on the brake pedel. If it stops, it's a lockup problem.
I'm still trying to figure out how to fix it. No one's helping me out
Old Aug 24, 2004 | 01:22 PM
Rockit_GTO's Avatar
I know it's a pain, but try rotating the converter.
Old Aug 24, 2004 | 05:19 PM
In case the converter is out of balance? Do you think this could be the problem if the vibration is only in one or two gears?
I think a one gear vibration would almost have to be a problem in the trans unless there are unknown factors.
Old Aug 25, 2004 | 10:58 AM
Rockit_GTO's Avatar
The 4l60e is very picky about weight. Heck, the guys that installed mine even weighed and made sure the bolts were all the same weight before reinstalling mine.
There were several posts about this before and several of us had success in rotating the converter to remove the vibration.
Old Aug 25, 2004 | 03:46 PM
It's definitely worth a try. I might give it a shot next time I have the car up.
thanks for the suggestion
Old Aug 25, 2004 | 06:12 PM
Roadrunner 45's Avatar
you can also try rotating the driveshaft 180 deg. to the pinion yoke. EVERY vibration I have ever chased in my car has turned out to be u-joint/pinion angle/trans mount vibration. Check the easy stuff first.
Old Aug 26, 2004 | 10:02 AM
Raptor99's Avatar
Exactly what I was thinking. If it was a weight imbalance, you think it'd be matched to the RPM/speed, not the gear it's in
Old Aug 26, 2004 | 04:37 PM
Originally Posted by Roadrunner 45
you can also try rotating the driveshaft 180 deg. to the pinion yoke. Check the easy stuff first.
I've done this. No relief.
Old Aug 26, 2004 | 07:37 PM
GrapeApe's Avatar
trans mount might be loose or crossmember
Old Aug 27, 2004 | 05:37 PM
MakoLS1's Avatar
also check your torque arm, i was haveing vibrations at higher speeds and i found the two botton bolts were almost out!!!
Old Aug 27, 2004 | 10:28 PM
electricz28's Avatar
i had a similar tranny issue, the Trans shop found a worn planetary. The trans has been rebuilt with Z pack cluthes and a bunch of other goodies. Also run a custom billet converter with a larger lock-up band, pretty trick stuff, this converter flashes about 3000 G of the brake. Hope you find out soon.
Old Aug 28, 2004 | 05:39 PM
Hyper Chick's Avatar
After my Yank install, I had chatter/vibration. We tried everything. Then we realized it was because the converter was locking up too low in the RMP range. I had some tuning done to adjust the lock and unlock points and all my problems went away and have not returned.
Hope this helps.
