Question about 0verdrive and Drive....
The lockup is programmed in 3/4 by the tune. once you get a 'verter & cooler & shift kit & nitto's you'll probably want a tune done on your car to tweak the driveability.
you don't really get any more power if you use the gas pedal to make the pcm shift for yah
stock converter = boring as hell. throw a 3500 on there and you wont have to dick around with d/OD at all.
The car feels faster though, when I force the pcm to shift.3500 on there and you wont have to dick around with d/OD at all.
I'll be saving up for a high stall, torque converter.
The coverter will lock up in third and fourth gear. If you want to see the coverter lock and unlock, drive on the freeway on level ground at a moderate speed, say 70. watch your tach. Then gently touch the brakes you will see your RPM raise a couple of hundred RPM. This is the clutch disinguaging. It will then lower after you let off the brake. The lockup will disingage off of the same sensor your brake lights and cruise control release works off of. The way a lockup coverter works is similar to the clutch in a manual in theory. when its unlocked at lower gear and speed the hydraulic turbine blades in the converter move the car, but allow for slippage. A high stall converter allows the car to slip into a higher rpm where the car will make more power to the wheels. When it locks up it is a solid connection just the same as a manual transmission
You may have been hitting the factory speed limiter.
I agree with the post above, that you're probably just hitting the rev limiter.
P-R-D-3-2-1 .... Now when you guys say driving with the shifter in " D " it's in 3rd gear ?
Also, where on the shift-board
is " OD " ... I feel so dumb
