Serious Problems After Transgo Install
Old Sep 8, 2004 | 06:15 PM
jurisz28's Avatar
Unhappy Serious Problems After Transgo Install
Well after trying to figure out why modifications in the video were not the same as the ones in the directions, I went ahead and did it according to the paper instructions. To my knowledge, I went through each step, double checking to make sure I didn't screw this up. Put it back together, the only difference being that I installed a drain plug in the pan towards the rear. Anyhow, after putting in six quarts, I added two more and put in drive and reverse to make sure they would engage. They did. I backed it out of the drive way attempting to go around the block. The 1-2 shift was firm, the 3-4 shift was firm. Stopped at a light tried to accellerate and it felt like it was slipping, but it slopped through the gears. By the time I got home, it was slipping badly. I checked the fluid because it just felt like it was low. I added two more quarts. I then tried to put it in drive and nothing happened, reverse and nothing. Total tranny failure. There were no leaks and it did not smell burnt. When I bolted in the valvebody, I torqued it according the shop manual (in a spiral order). I got no check engine lights. I will be putting it on the scanner tonight to see if there are any electrical problems. But, has anyone ever had to go through this because of a shift kit install??? I'm sort of a pesimist and have already been looking at buying a replacement tranny. I'm still in shock that it only lasted 10 minutes.Any input would be much appreciated.
jurisZ28
Old Sep 8, 2004 | 06:37 PM
TeamTripp's Avatar
First off, 10 quarts is WAY to much! 5-6 quarts is all thats needed after installing a transgo, unless you have a huge transmission pan.
One of the most common mistakes is not getting the boost valve snap-ring fully seated in the correct location. There is a "step" and a "groove". Most people get the snap-ring at the bottom of the step and it blows back into the pan.
Old Sep 8, 2004 | 09:49 PM
jurisz28's Avatar
Actually, I started with 6 then went up because it seemed to run like it was low on fluid. I can certainly understand the possibility of that valve blowing out. I remember snaping it into place and then pushing against the spring a few times to see if it would fall. It wouldn't surprize me at all that the little booger is in the pan when I drop it. Thanks for the info.
Old Sep 9, 2004 | 04:10 PM
SAPPER's Avatar
Definately sounds like too much fluid. I've done that before.
Old Sep 10, 2004 | 09:50 AM
Wesley SS's Avatar
Sounds like too much fluid to me too, go back and check the level.
Old Sep 10, 2004 | 02:35 PM
jurisz28's Avatar
I understand that its too much fluid. However, the problem started at 6 quarts. At that point, the car wasn't responding in drive or reverse. I then added the fluid as I thought it was low because there was absolutely no response. I'm going to drain and drop the pan tomorrow to see what it might be.
Old Sep 12, 2004 | 01:06 AM
jurisz28's Avatar
Thumbs up
You hit the nail on the head. I dropped the pan this afternoon and there it was, the boost valve and all sitting at the bottom of the pan. I reinstalled, making sure it wasn't going to go anywhere, refilled properly, and it worked perfectly. Thanks for the advice.
JurisZ28
Old Sep 12, 2004 | 06:46 AM
TeamTripp's Avatar
Glad I could help. Enjoy.
