Braided line trans cooler lines 4l60e
If you look at the OEM QD.. it is a Straight Thread, not Tapered, the correct type of fitting should be 1/4" NPS not NPT.. you should not use a taper thread.. as it will not seat and if you keep tighting it, it well crack the case..
The correct adapter is a 1/4" NPS with a gasket to seat.. But many have used the NPT and it might seal most of the times.
BC
BC
Here's the correct way to do it. I've laid it all out including part numbers.
https://ls1tech.com/forums/automatic...oler-line.html
I ended up getting jegs brand AN lines and hose for my install. I used 6 AN fittings and line, it turned out pretty good.
I got the special 4l60e -6 AN x 1/4 NSPM fitting for the tranny and 6 x 16-1.5mm Inverted Flare AN fittings for the radiator off ebay.
Considering that some of the information in this thread is going back EIGHT YEARS, I just updated a bunch of things. I've long known the threads in the case are 1/4" straight, not tapered and have even seen incidents of folks threading in a NPT fitting and cracking the case from all the spreading force being concentrated on the outer-most thread of the case.
Personally, if I were building a transmission for a custom installation I'd re-thread the ports on the case with a 1/4" NPT tap and lock-tite a pair of inexpensive -6AN fittings into it. The NSPM Fittings are another option that's even easier at additional cost.
I tried several different hard lines (2000 silverado, 1999 S10) and this was a quicker and easier solution
Moderator
UPDATE - The AN-6 Male-to-Male adapter with O-Ring fit perfectly into my 2008 4L65E case, -BUT- when I just swapped in a 2001 trans, it did NOT fit. Looks like most 4L60E have 1/4" NPS threads as mentioned above, but 2008+ have a different thread. Lovely.
#32
Moderator
Or you could use these AN fittings with NPSM thread made specifically for the 4L60E/4L80E trans in either -6 or -8 AN size.
The fittings are made by Fragola and Summit's part number is: FRA-481670-BL
(Since Summit is out of stock, I am ordering them from an ebay seller.)
#33
If summits is out of stock try this number 1-800-201-2066.Please contact me for a professional consultation regarding your needs. We are happy to provide you with references both here in the United States and Internationally. Be sure to check out our website at maddogtransmissions.com
Hear what our customers and fans say on our Facebook Page at www.facebook.com/maddogtransmissions
We also accept orders over the phone. Be sure to contact us and we will recommend the correct transmission for your application. For your convenience, we accept PayPal and all major credit and debit cards.
If you prefer, we can call you personally, just e-mail us your phone number.
All our transmissions are very strong and reliable, and can be used for everyday driving. Extended warranties are also available.
Thank You,
"Mad Dog" Lou
Mad Dog Transmissions
Phone 770-781-0949
Fax 770-781-0969
Web: www.maddogtransmissions.com
Facebook: www.facebook.com/maddogtransmissions
Twitter: www.twitter.com/maddoglou
YouTube: www.youtube.com/maddogtransmissions
Thank You,
"Mad Dog" Lou
Phone 770-781-0949
Fax 770-781-0969
#34
Not sure what was up with my car, just finished this install. The 16-1.5mm Inverted Flare was considerably larger than my 2002 Camaro Radiator fittings. I used a Russell Part 640330 Adapter Inv Flr, straight, -6 (1/2" -20), it threaded in perfectly to the radiator.
Thanks for the tips!
