A4 snapping like twigs!!!
Old Oct 19, 2004 | 02:46 AM
OldSchoolSleeper's Avatar
Default A4 snapping like twigs!!!
I'm not that educated on transmissions but I"m trying to learn. I have been told that the 4L60E and a 700R4 are mechanically the same so the parts are interchangable. I don't have the luxury of electronics in my 68 so I'm stuck with the 700R4 and I keep snapping them. How are you guys keeping them together in a 10 sec pass and spraying 200 hp... I wasn't near that and I've split a planetary and then ballooned the shell (?)..
ANYONE that is having luck with thier A4 please post what you had done to it. There is a new 5 gear planetary out, is anyone using it??
thanx
Old Oct 19, 2004 | 03:09 AM
White98Z's Avatar
Get a dif tranny
Old Oct 19, 2004 | 07:20 AM
patriot68's Avatar
the 4l65e has a heavy duty input drum and 5 pinion planets and will interchange with a 700
Old Oct 19, 2004 | 07:34 AM
BlownCV8's Avatar
4l80E........Do it, do it soon!
Old Oct 19, 2004 | 08:42 AM
Silvr98z28's Avatar
Give Chuck a call @ FLP a call. They are sponsors.
I've been kicking the **** out of mine for a while.
Old Oct 19, 2004 | 09:29 AM
2MuchRiceMakesMeSick's Avatar
Get a TH400, that should handle a 200 shot
Old Oct 19, 2004 | 06:45 PM
SmokingWS6's Avatar
He can't do electronic, but if you still want overdrive get a non electronic 4L80
th400's are the answer but the GV overdrive unit is not practicle due to the price.
Old Oct 19, 2004 | 07:55 PM
Automatics's Avatar
Restricted User
I will be glad to answer your questions on how to make the 700R4 live. Give me a call at 800 7763288 anytime after 12 noon PST.
Old Oct 19, 2004 | 10:06 PM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
I second that chuck is a great guy to do business with. I also have a 4l60e tranny with manual shift with a pro race direct port system and holding strong. Times in sig are nitrous setup motor passes
