Problems installing transmission cooler
Old Oct 20, 2004 | 09:51 AM
johnpate01's Avatar
Default Problems installing transmission cooler
I have the Hayden 28,000 trans cooler for my 99 TA and have almost got it sorted out except that I can't get the little plastic zip tie pieces to feed throught the fins on the radiator/AC condenser. Do you think that its safe to try to push a metal rod through first to separate the fins. Any other mounting ideas? Thanks
Old Oct 20, 2004 | 02:05 PM
John_D.'s Avatar
Should be fine to push something through the fins, as long as you don't hit one of the ribs.
I made a little mounting bracket out of some spare pieces of bracket metal I had sitting around. Just stuff I had accumulated over the years. Similar to that metal plumbers tape (the strip with holes every 1/2" or so), only thicker.
But I had a little more room to work because the a/c condensor is gone and most of the styrofoam behind the front bumper is gone too.
Old Oct 20, 2004 | 04:17 PM
jimmyblue's Avatar
Moderator
I had no trouble getting mine through; you might want to
try and sharpen up the points and make sure the thing
is relatively straight. You do have to find a point that is
between the tubes but it will go eventually. Just wiggle
it easy until it gives and goes through.
Old Oct 21, 2004 | 12:03 PM
johnpate01's Avatar
thanks guys, i'll try those suggestions.
