Shift Points?
Old Nov 23, 2004 | 01:37 PM
98Raptor's Avatar
Default Shift Points?
My peak hp on the dyno showed at 6800-6900.
Stock engine with the exception of the cam (232/236 .595/.601 114+4 LSA) and 918 springs.
700+ hp competition 4L60E tranny with a 4400 stall converter with 2.7str.
Where do you guys think my shift points should be?
Old Nov 23, 2004 | 04:30 PM
sz0077's Avatar
if i were you id put a ratchet shifter or equivalent in your car and go- shift it yourself
Old Nov 23, 2004 | 05:27 PM
98Raptor's Avatar
I am not interested in doing that. I want consistency.
Old Nov 23, 2004 | 05:34 PM
Need2gofaster's Avatar
dont you think you are pushing th issue with the 918's? i would be very carefull spinning that thing 6800-7000 rpm's with the stock bottom and the 918's...other than that i would try them at 6500 and go from there and work your way up and see what your times are.
Old Nov 23, 2004 | 08:06 PM
98Raptor's Avatar
Right now the shift points are at 6600.
Old Nov 23, 2004 | 08:33 PM
have you taken it to the track and tried to adust there? make 3 or 4 runs and then change them and see what the results are....i had to back my shift points down some and it really helped me
Old Nov 24, 2004 | 08:47 AM
98Raptor's Avatar
I actually do not have that ability at this time. I sold my programmer and am useing a local shop to do my tuneing now.
Old Nov 24, 2004 | 05:41 PM
MNR-0's Avatar
Advance the cam a little, making sure you still have enough room with IVC event. Cheaper than blowing an engine and will likely reduce your ETs. 6600 is plenty of shift point, unless you are a top loader.
