need Help ASAP
Old Dec 3, 2004 | 10:47 AM
GREATWHITE's Avatar
Default need Help ASAP
hey guys, My g/f has a 95 V6 a4 camaro. It will not shift out of park due to I think the shift lock solenoid? The one where you have to hit the brake to shift. I need to know if I can remove it and where is it located?? thanks in advance!
Old Dec 4, 2004 | 12:23 AM
01WS6/tamu's Avatar
Pull the top off the center console. Locate the lock out solenoid at the fron of the shifter area. Take a screwdriver and pry the arm off the shifter disconnect the connector and locate the nearest trashcan.
Old Dec 4, 2004 | 09:24 AM
GREATWHITE's Avatar
Awesome, thank you very much!!!
