Is it true Hurst has a ratchet shifter for A4?
Old 07-14-2006, 11:31 AM
  #81
ss4chad's Avatar
It would be awesome to have a B&M 3500 Stall, Cooler and shifter all in one neat package. You could call it "The LS 35 Kit" or for a 3000 stall call the package "The LS 30 Kit" and so on! Hey it was just a thought!! Cant wait to see that new shifter under my Christmas Tree!! WOO HOO!!!!
Old 07-14-2006, 11:58 AM
  #82
'Trust''s Avatar
Pardon my ingnorance.. but what exactly does a ratchet shifter do?
Old 07-14-2006, 02:42 PM
  #83
12secSS's Avatar
Although it will be a direct replacement for a stock shifter, it is mainly for those looking to manual shift their automatics, regardless if they have a manual valve body or not. The ratcheting mechanism works by positively locking into the next desired gear shift to avoid overshifting. The stick or handle will return to the previous location for quick access to the shifter, where you can also engage the next gear when ready. Great for drag racing, or even road racing/auto-x (if so desired). This will work with all GM automatic transmissions.
Old 07-14-2006, 04:40 PM
  #84
HaulinHawk's Avatar
I just got off the phone with Drew from B&M and he said that within 3 months they should have a something to look at. He said their engineers had a rough draft for the shifter but it had not reached a production status as of yet but he said to tell everyone to call back in 3 months, October maybe, and get a status on the the propsed new shifter! Looks like it might be ready just in time for Christmas with any luck. He also said to make sure that you guys & gals (LS1TECH) are calling B&M requesting it, he says it puts a little heat under the feet of engineering to get it done and on the market. So make the call today!! 818-882-6422 is the number!!
Hey guys i just called b&m and talked to drew make sure you guys call and talk too him as this is not a done deal yet ,the product is in the design phase but hasnt been approved yet.the more calls he gets the more heat he can put on the big dogs to approve it.
Old 07-14-2006, 04:52 PM
  #85
12secSS's Avatar
Uhm, it is approved and the engineering dept. is already working on the production design. The "big dogs" are well aware of the potential for this product. Doesn't hurt to keep calling.
Old 07-14-2006, 10:41 PM
  #86
ss4chad's Avatar
Personally I would love to see the 'Quicksilver' as a model available for our cars. It would still retain some of the original look of the factory but with a huge advantage over it. I think that is one of the cleanest shifters in the world. Not alot of BS hangin on it. You could even drill a hole in the side of it to adapt a Nitrous switch!! I cant wait to see what B&M comes out with, I'm sure it will look great!!
Old 09-25-2006, 10:08 AM
  #87
FACE's Avatar
How about for C5's?
Old 10-14-2006, 08:34 PM
  #88
CBX
CBX's Avatar
Originally Posted by FACE
How about for C5's?
Ditto.
Old 11-25-2006, 10:50 AM
  #89
steve40's Avatar
is this shifter coming out?
Old 11-29-2006, 12:26 PM
  #90
stevewix's Avatar
i'll buy one today!
Old 10-20-2008, 11:27 PM
  #91
BobDoLe's Avatar
part number?
Old 10-21-2008, 07:46 AM
  #92
BlackTA96's Avatar
so did any of this go through???
Old 10-21-2008, 12:48 PM
  #93
TXZ28LS1's Avatar
anybody know where u can get a hurst T-shifter for our 4L60E?
Old 03-28-2009, 08:42 PM
  #94
johnson73801's Avatar
bringin this one up again but is anyone makin a shifter yet?
Old 04-23-2009, 10:55 AM
  #95
Moderator
Black LS1 T/A's Avatar
You can get the Hammer Shifter to work in our car:
Old 04-23-2009, 06:03 PM
  #96
12secSS's Avatar
Wow, talk about an old thread. Since my departure from B&M, this project went the way of the dodo bird. With some creative modifications any shifter will work in a late model F-Body.
Old 04-24-2009, 12:31 PM
  #97
Canada's Avatar
Too bad there is nothing for an auto GTO. They are linkage instead of cable.
Old 04-24-2009, 01:17 PM
  #98
Gingervitis Addict
slow67's Avatar
Remove all of the linkage, and use a shifter that uses a cable.
Quick Reply: Is it true Hurst has a ratchet shifter for A4?
