need help i broke my pump
Ryan
if you can get them off, then i don't see why you couldn't replace the pump if you had a service manual. although- im not sure if it is connected to anything integral and you would have to take the whole trans apart.
i say call up a local trans guy and ask how hard it is- maybe try a few different guys since they may lie and say it is difficult and let them do it for alot of $.
good luck.
No offense but if you cannot install a converter don't mess with the pump, have someone else do it.
So what broke in the pump?
You could probably take the pump apart and replace the rotor, vanes and rings. Or have someone else replace that stuff.
You can also measure to the mounting flanges on the converter to see if it is in the trans all the way. Lay a straightedge across the trans bellhousing on the face that meets the engine, then measure down to where the converter will contact the flexplate.....it should be 1 1/8".
