Converter?
Old Dec 28, 2004 | 08:32 PM
Silver02's Avatar
Default Converter?
My car stalls sometimes when I put it in gear especially when cold. This is due to the cam. Once it's in gear, it runs fine. Will putting a stall converter on cure this problem?
Old Dec 28, 2004 | 10:59 PM
CamaroCain's Avatar
I see you have a cam in the car, with unknown specs. I dont think a converter will help the problem any. Either need some more tuning tweaks or you just need to let it warm up/idle a little longer before you put it in gear.
Old Dec 28, 2004 | 11:06 PM
99ssleeper's Avatar
Doesn't a stall converter convert stalls to no-stalls?
Old Dec 29, 2004 | 01:38 AM
Silver02's Avatar
With the stock converter, the car wants to jump as soon as I put it in gear which makes the revs drop. Won't a stall converter prevent that?
Old Dec 29, 2004 | 09:08 AM
Casper9T9's Avatar
A converter should definitely help. But you should want a converter to go faster, not just to fix a stalling problem.
Old Dec 29, 2004 | 05:07 PM
68birdls1's Avatar
i hope you bought your ca like that instead of doing all of that work to it before you did a stall. but i think you should definatly get a stall. you will not reget it.
Old Dec 30, 2004 | 04:53 PM
Silver02's Avatar
I know the converter will make the car quicker but I just want to know if will stop the car from lurching when I put it in gear causing the revs to drop?
Old Dec 30, 2004 | 08:39 PM
next's Avatar
If your car is lurching hard and that's causing it to stall, a converter will definitely help. Will also probably make the biggest gain in performance for you also.
